Question about HP 336044-B21 8-port KVM Switch
Need power supply for Hp 336044-B21 KVM Switch. (DVE Switching Power Supply, Model DSO-142L) in the last two month I lost three same switches with the same problem - power supplies...
  • 77 Answers
There are a few things that you can do. First; try to go online to HewlettPackard.com and locate the power supply. Second;go online to ebay and search for the power supply. Last;locate a Batteries R Us store in your city. They have a huge supply of batteries and power adapters. If you do not find a HP adapter the store person can help you find one that is complimentary to your HP adapter.
Posted on May 29, 2009
Problem:HP 336044-B21 8-Port KVM Switch do not seems to function properly, green light is not coming, sometime blinking, rack monitor do not show any signal coming from server, although the cable from...
You may have a bad ethernet cable. I would try the easy thing first and just go to Best Buy, Amazon etc... and purchase a new RJ45 CAT5 or CAT6 ethernet cable. Since you are receiving an orange light it is indicating that the port is not active. Also check the cable make sure its seated properly at both ends even with a new cable. Cheers! Hope it helps! J the Guru.
Oct 16, 2017 | HP (336044-B21) 8-port KVM Switch
How to repair the dso power supply ? is there a circuit diagram ? thx
repairing a power supply do not need a diagram often faulty on a power supply are the regulator transistor,capacitors,resistors,and diodes. just check these parts and you can fix the power supply.check also for loose contacts and connectors this also cause a fault on the power supply.
Jan 18, 2011 | NetGear ProSafe JFS524 24-Port Ethernet...
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
Need a power supply for Beyond Micro BMMDU2 drive. What is the voltage and current rating? Also, has this company been rebranded?
Mine came with a "DVE Switching Adapter":
(Model: DVS-120A15FUS
Input: 100-240V ~ 50/60Hz 0.7A)
Output is +12V, 1.5 A
Diagram indicates that the outer shield is negative, I think.
Jan 17, 2010 | Beyond Micro Computers & Internet
Switching power supply ??
For your purposes there is no difference: all you need to know is the voltage your WD drive requires, and the maximum current load it needs. Any regulated DC power supply with that voltage and *at least* that current will do.
Not-so-technically, a "regular" power supply will supply power at the correct voltage by "discarding" a portion of the extra potential. A "switching" power supply will shunt and switch the extra power away, so that instead of being "lost", it is "not requested" from the uplink grid. In theory a perfect switching supply will have no losses, and therefore dissipate no waste heat (in practice there will be some losses, and cooling will be needed). The important thing, though, is that a switching power supply can deliver twice as much power as a "normal" supply, and the same power in a half as big package.
Jan 03, 2010 | Computers & Internet
I cant find my HP COMPAQ 7100 WINDOWS INSTALLATION CD
Your only course of action is to contact HP help line or go online via another computer to www.hp.com
Unless the machine is a relic they should be able to supply you with both
Aug 18, 2009 | Compaq 262585-B21 16-port KVM Switch
Defect internal power supply DSO-142L from HP KVM. Replacement ??
Remound a universal power supply rework the internal baseplate to fit the new power supply and everything will work again
Ron W
It expert
Jul 16, 2009 | HP 336044-B21 8-port KVM Switch
Power supply fail DVE DSO-142L
The output + 5.1v/2.4 Amps and -5v/0.5Amps DC
Input is AC 100/240 VAC 50/60 Hz
Jun 05, 2009 | HP 336044-B21 8-port KVM Switch
DC Power supply specifications
here is the info you need...
Input Power 100~240V, 50~60Hz
9V DC,1A Max
Hope this helps...
Feb 09, 2008 | Computers & Internet
HP 336044-B21 8-port KVM Switch Logo
3,341 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
