Question about Kitchen Ranges
I have a GE JKPL360P28G oven that does not get hot. I have change both element and neither get hot with the stat set at 375 degrees
    Brigadier General:
  • 8,619 Answers
Hi!
There are so many reasons due to which the oven is not getting hot as given below:
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
Many electric ovens use the broil element, too, during the pr-eheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
When you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 29, 2009
GE wall oven jk95550f1ss When set for 400degress, my pro oven thermonitor registers 375 degrees
If you are certain your oven thermometer is accurate and the oven thermostat is electronic there might be a calibration adjustment a service engineer could make.
375 does err on the safe side. An oven is not an industrial furnace and so being built down to a price usually has certain quirks - hot parts and cooler parts and housewives (and others) usually take great pride in "knowing" their own ovens just as a shooter knows his rifle and will soon unconsciously begin to compensate for a sight that is "off".
Sep 28, 2017 | Ovens
Can you calibrate OV310E temperature,oven says its at 375 degrees but its only at 340,changed probe still the same. checked with oven thermometer
oven thermostats are not exact in operation and every oven is different in insulation qualities
all cooks have to get to know the oven temp settings from the dialed setting
check that the door seal is good and the door is properly adjusted
of course you can always get a technician out to see if the elements are working to capacity
Feb 06, 2017 | Kitchen Ranges
I have a Kenmore model 911.4658816 and the oven does keep a accurate temp. if set to 200 degrees for example it may only go to 180 or so. baking does not workout as items are always uncooked in the middle....
@00 or 180, does not spoil cooking. If that is your only problem, then set oven to 220 or 230 with your thermostat in the oven. Then compare the reading in the oven to the one on the control panel.
You can then set the stat on the control panel to higher or lower, to compensate for the difference.
A new stat might not make that much difference as other issues might be involved.
Oct 19, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven over heating , from set temp of 375 to over, third time the
Have you changed the oven sensor. If you have the problem is with the main oven control. Let's hope sensor for cost.
Feb 01, 2010 | Ovens
OVEN DOES NOT HOLD TEMP SET ON 550 AND 375 WAS
sounds as though one or more of the hearing elements are blown , should be one on each side and a ring type around the fan, these are not always visable
Oct 20, 2009 | GE JSP26 Electric Kitchen Range
Oven temp set to 375, reads 375; after 10 minutes internal thermometer shot up to over 550 degrees
You need a new t-stat on this unit/ YOu can call us with the brand and model number and we can get the proper parts for you. Hope this helps you out! Thanks, Ella!~ :>)
Aug 17, 2009 | Ovens
GE JKS06 won't heat up past 200
Hi.
Could be that main oven stat is faulty, and also there is a possibility that the thermal overheat stat is coming in sometimes caused by poor ventilation.
Also there is sometimes a secondary element fitted to cookers which is not always obvious.
More investigation is needed.
Nov 19, 2008 | GE JKS06BFBB Electric Single Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
