Question about Technics SL-1200MK2 Turntable
The 45 rmp button on my technics 1210 has seized up. and comes loose again after bieng pressed exesively. i have tryed oiling it. what else could be wrong?
  • 69 Answers
You wanna take it apart and give it a good clean carefully
Posted on Aug 07, 2009
Hi having a problem !!
If it has a belt drive, the belt has to be replaced.
Mar 22, 2015 | Technics SL-1210 Turntable
Technics 1210 mk2
As everything was normal before you started the work, I'm thinking you might have disturbed something. Such as caused a wiring plug to come loose. Maybe even a bad solder joint somewhere?
Apr 28, 2014 | Audio Players & Recorders
My technics 1210 is giving out an un-balanced signal
Hi, most likely the cartridge is shot. If you have a second cart try that on the unit and see if it makes a difference. Other possible causes are the stylus tip is damaged on one side or the output cable or rca connections may be loose. Cheers John. Styluscity,com
Dec 08, 2011 | Technics SL-1210 Turntable
There are 2 problems with the my deck: 1. The +-0 light for the pitch will not work but everything else about the pitch works fine. 2. The deck will not change from 33bpm to 45bpm, I have replaced the...
Hi, please do this test for me. With the deck running on 33 speed and the pitch control set to 0 use your finger on the platter centre and speed it up manually as much as you can. Doe's the quartz lock lamp come on? If not then open the deck up and loosen off the fixing screws on the circuit board that has the 33/45 buttons. Try to change speed with the board loosened off. If none of the above makes any difference replace the quartz lock neon. Use only original Technics neon. As a matter of interest have you done any mods to the deck? Cheers John,
Sep 29, 2011 | Technics SL-1210 Turntable
1210 tone arm won't stay down. When I unscrew the
Check the point where the arm piviots, maybe a screw has come loose. Depending on the type of cartridge it should track at 3 to 4 grams.
Jun 08, 2011 | Technics Audio Players & Recorders
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
Technics 1210 pop up light?
Maybe you should try putting a smaller (in Watts) lamp in the pop light...
Nov 09, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
117 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
