Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer will not turn on
When I press the on/off switch the printer will not turn on. all connections from printer to pc are firmly in place.
    Scholar:
  • 34 Answers
First make sure that all cables are plugged in securely (wall to cube, cube to printer). Also make sure that the outlet you are using is good (plug a light into it). If all of these things have been checked and the power light still doesn't function, you may have either a bad transformer (cube) or there may be a problem with the printer. If you have a multimeter, you may be able to check to see if the transformer is providing the correct power (I know it has a funny end).
Note: The power should come on even if the USB plug is not in the computer. You may wish to unplug the USB cable first to see if it will turn on.
Hope this helps - Flub
Posted on May 29, 2009
  • 489 Answers
Check power source. Also, if you have a voltmeter, check the power going into the printer. If all is good there, unplug the printer from the computer and try to power it on. If it powers up while not connected to the computer, this could indicate a problem with the USB cable or the port on the computer. Try another cable or available port (if you have one). If the printer is connected via an external USB hub, try connecting it directly to the computer instead. If none of these work, post back here & I'll assist you further.
How do I fix paper jam problem
  • Turn the printer off and on.[This automatically clears any stuck papers in the paper paths.
  • Disconnect the printer from the PC and unplug from power.Reboot the PC.
  • Connect the printer again.
  • Make sure the printer's top cover's is firmly locked in place.
  • Remove the papers in the paper tray
  • Check through the paper paths for any obstructions.
  • Open the cartridges section and look through for any papers stuck here and gently pull them out.
  • When loading papers,make sure the paper feed tray is not filled to capacity.
Hope this helps.Thanks!
Dec 18, 2011 | Canon Office Equipment & Supplies
My I900D Canon printer Prints But the paper is blank.I have tried printing from pc and testing only with the printer still blank paper. Can you help me?
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back.
And change the cartridge (Place a new cartridge instead of the old one)
4) Now switch ON the PC(only PC and not the printer)
5) Let the PC boot up and login to windows.
6) Now switch on the printer, PC should detect the printer automatically now.
Now you will be able to print.
Oct 17, 2011 | Canon I900D InkJet Photo Printer
HP PSC 1510 ALL-IN-ONE IS NOT FUNCTIONING, ALL LIGHTS ARE BLINGKING.
This means that the PSC 1510 has a fatal error. Try resetting the all-in-one - turn off the unit. Unplug the power cord from the printer and then from the wall. (Also disconnect the data cable - it's not required but can help.) Wait a few seconds then reconnect the power cord (wall and then printer). Turn on the printer.
Check that the control panel overlay is properly installed and connected. (If the printer has worked until recently, do not pry up the overlay. Just press down firmly to make sure the adhesive and pins are situated properly.) If this is a new printer, turn off the unit, unplug the power cord and lift up the scanner lid. Then install or reseat the overlay. Make sure the tabs are in the slots and then press down firmly on the edges to secure the adhesive. Then put on the faceplate. Close the scanner lid, plug in the power cord and turn on the printer.
If the above solutions do not solve the problem, then the all-in-one needs service. If it is under warranty, contact HP. Otherwise, decide if it is worth repairing (and the cost of shipping to a service center, if you don't live close to one).
I hope this helps.
Jun 08, 2011 | Computers & Internet
I placed new ink cartrages in printer and hit ink botton and it just keeps blinking,
First, Make sure you have purchased the correct type of ink for your printer model. Second make sure the cartridges are pressed firmly into place. They should make a "click" sound when pressed into place correctly. Third make sure the cover is closed on the print head and the printer access panel is closed. If you have checked the above try powering the printer off and on again and pressing the ink refill button two times.
Mar 04, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Kodak printer states printhead loose or missing, this error message came on when I replaced the introductory color cartridge, which occured 1 week after taking out of box.
To resolve this error:
  1. Open the printer access door.
    Disconnect the power cord
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead.
    • Unlatch the printhead:
      press the button in the upper-left corner of the carriage.
    • Lift the printhead out of the carriage.
    • Place the printhead in the carriage.
    • Press firmly against the target label on the printhead until it clicks into place.
  4. Install the color and black ink cartridges.
  5. Close the printer access door.
  6. Connect the power cord.
  7. Then follow the instructions on the LCD screen
Jan 23, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
HOW DO I INSTALL THE INK CARTRIDGE IN PHOTOSMART C4280
Turn on power to printer, then lift the top half of Printer lid, the cart holder will move to centre, place printer cart in the holder rack, press firmly in place.
Jun 07, 2010 | HP PhotoSmart C4280 Laser Printer
The paper won't feed through the printer- anything I can do for that?
Clean & inspect: Unload the paper stock. Turn printer off & unplug its power cord. Open the rear access door by pressing the tab on its left edge towards the right as you swing the door out. Remove & discard any jammed &/or crumpled objects. Clean, turn, & inspect the rollers with a soft towel that has been lightly moistened with water. Rollers that do not turn freely could require replacement.
Prepare printer for use: Restack & reload the paper stock into the paper supply tray, but do not continue to push the paper in after some resistance is felt. Reattach the rear access door by lining up the two pins on right side with their respective holes (near the ports for power & USB connections) & swing the door back into place—pressing gently but firmly until it locks into place. Reconnect the power cord & turn the printer on.
Jun 04, 2010 | HP PSC 1210 All-In-One InkJet Printer
Only printing top lefthand quarter of the image on screen
Try switching the computer and printer off, then detach all the leads between computer and printer. Plug the leads back in very carefully and firmly. Also check that your internet connection (ethernet) leads are firmly seated in the back of the PC, and your router. Then switch back on. Any improvement? Does replacing the leads help?
I had a very similar problem on my 5550 model (it wouldn't print from internet) - and found this solution by accident. Perhaps it will help you. If not, hope someone else can help.
Nov 14, 2008 | HP DeskJet 5550 InkJet Printer
My Heward Packard desktop 932C will not connect to my Dell laptop
what kind of connectivity you are trying to connect, most connectors comes as a USB cables, this comes as a easy connector that should be no problem at all, pls follow this info...
This document describes the hardware setup for a new printer. Unpack the printer
  2. Turn the knob on the rear access door of the printer counter-clockwise.
  4. Push the module back into the printer until it snaps firmly into place. (Do not press the buttons on the ends of the module while replacing it.) c00107976.gif
Insert paper
  1. Slide the paper adjuster out as far as it will go.
  2. Flip up the OUT tray so that you can see the IN tray more easily. c00107977.gif
  3. Place up to 100 sheets of printer paper face down in the IN tray.
  4. Slide the paper adjusters to fit snugly against the edges of the paper.
Turn on the power
  1. Locate the power module for the printer.
  2. Insert the rectangular end of the power supply cord into the power outlet on the back of the printer.
  3. Insert the two-prong end of the cord into an electrical outlet. c00107979.gif
Insert cartridges
  1. Open the top cover of the printer. When you open the cover of the printer, the RESUME button will flash until you close the cover. The printer part that will hold the cartridges (called the cartridge cradle) moves to the center of the printer.
  2. Remove the ink cartridges from the box.
  3. Remove the tape from the cartridges. c00107981.gif CAUTION: Do not touch the copper contacts (on the back of the cartridges) or the ink nozzles (on the bottom of the cartridges).
  4. Lift the cradle latches inside the printer.
  5. Hold the black ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  6. Push the black ink cartridge firmly down into the cradle on the right. c00107982.gif
  7. Hold the color ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  8. Push the color ink cartridge firmly down into the cradle on the left.
  9. Close both latches. When you push down the latches, you will hear a click and feel resistance.
  10. Close the lid of the printer. You will hear the sound of the cartridge cradles as they move to the right side of the printer.
Attach the printer Attach the printer to the computer with a parallel cable or a USB cable. Print a test page Turn the printer on and press the RESUME button to print a test page.
  1. If the RESUME light continues to flash, press it again.
  2. If the printer cable is firmly attached to the printer, then check to be sure that the printer cartridges are seated securely in their cradles.
  3. If the printer cartridges are seated firmly in their cradles, then check for any tape or packing material that you may have left inside the printer or on the cartridges.
  4. If you press the RESUME button for too long, you may print several test pages unnecessarily.
check it out.... goodluck
Jul 27, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
