Question about Cyberhome CH-DVD 300 DVD Player
Picture rolls picture horizontal rolls with or without disc-makes hissing noise
  • 132 Answers
It come from TV itself because a difference synchronization IF YOU HAVE SUITABLE KNOB IN TV TRY TO MOVE IT A LITTLE IF NOT YOU NEED A TECHNICIAN TO SEE BOOTH A TV & DVD
Posted on Jun 03, 2009
I have an LG42PB tv with no picture or sound but it makes a hissing noise from the speakers. Also, there doesn't seem to be any response from all other buttons at the bottom of the tv
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Mar 22, 2016 | Televison & Video
Hissing noise horizontal lines
Hello erl, hi.... the hissing noise is usually caused by high voltage arching, but this is suppose to be soft. if the hissing is unusually loud, the high voltage transformer clip cap may be loose, this may cause the horizontal line you see on the screen. take precaution when dealing with this.... here are steps that may help..
1. unplug the unit. allow around 5 minutes for all voltages inside the unit drops to a safe level.
2. open the back cover. place the monitor face down on a table with a dry clean rug or towel.
3. locate the picture tube. on the top side you will see a wire with a cap at the end.
4. use or wear a cloth glove and feel if the cap is loose. re clip the cap and make sure it is secured.
5. replace the back cover.
Feb 15, 2012 | Philips Computers & Internet
Hissing noise heard when brake pedal is appilied. changed master cylinder, rear wheel cylinders front pads and rotors what is solution?
Is there any problems with the brakes besides the noise? If theyre acting up, it could be your brake booster. It's hard to determine without more specific details, brakes always make a quiet hissing noise, depends on where, how loud, how the pedal feels...
Oct 19, 2010 | Chevrolet S 10 Cars & Trucks
Picture displays horizontal roll
It's the Satellite Disk that is the problem. Just call the guy..
you can also try to unplug and plug it back in.
Oct 23, 2009 | Philips Magnavox 20MS3442 20" TV
There is a hissing noise in back of tv and picture goes on and off zenith d36d51
Hissing noise and picture on and off means faulty flyback transformer, it has a small crack and voltage is leaking out, replace the flyback, if tv still not working replace horizontal output transistor (broken flyback could blow the transistor).
Aug 09, 2009 | Zenith D36D51 36" TV
Hissing noise in freezer
When you observe this is your compressor quiet? Then most likely your refrigerator is in defrost mode. The water is coming off the evaporator (think of a very cold radiator) as the defrost heater element warms. This element is similar to the electric heating element in the bottom of your electric oven. the water hits it and it will hiss. This is part of the normal operation of a refrigerator. The defrost cycle usually lasts from 20-30 mins and will occur 4-6 times a day. If you are having trouble with frozen food melting then re-freezing, or the temps are on the warm side, you might need to have your defrost timer or defrost termination switch looked at.
May 26, 2009 | KitchenAid Refrigerators
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
PROBLEMS WITH VERTICAL ROLL
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
Jun 28, 2007 | Sony KP-53S65 53" Rear Projection...
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Cyberhome CH-DVD 300 DVD Player Logo
99 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
