Question about Garden
Carb Adjustment on Stihl FS %%T LA Screw
Son messed with Adjustment screws and do not have the adjustment spec. for the screw labled LA
  • 1,040 Answers
Turn both screws clockwise, until they snug down. then turn them counter clockwise 1 1/4 turn. try starting. Make gradual counter clockwise turns, up to two full turns on each. (Settings on screws should not be beyond two full turns. ) Continue different combinations between screws until it starts. If you need further assistance, feel free to ask.
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker Jun 04, 2009
    Did you figure out the adjustments?
    Jim
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
My Stihl 021 chainsaw don't have but two
Gently Tighten the screw until you can not tighten it any more, then unscrew the screw once 360 (1 full turn) then unscrew a furthe 180 (half a turn). Your adjustment will then be set correctly
Oct 02, 2014 | Garden
I have a stihl 025. the carb i had had 1 adjustment the replacement carb has 2 set screws, what should the settings be to get started with
Usually when purchasing a new Carb, they are set very close. No adjustment needed. But if you want to play, turn both the High and Low screws all the way in then turn them bot out about 1.5 turns. that should get it started. The you will need to tweak the High sped and then the low speed and then the Idle
Dec 06, 2013 | Stihl Chainsaw 42mm Piston Rings 025 O25...
Repair manual
Hi Robert:
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Bud
Oct 03, 2013 | whipper snipper stihl fs 38
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Please take time to rate me
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
What do you mean by LA in the chainsaw?
Locate the adjustment screws near the carburetor labeled with an "H," an "L," and an "LA." The "H" screw adjusts the high speed fuel-air mixture; the "L" screw adjusts the low speed fuel-air mixture; and the "LA" screw adjusts the idle speed.
Jan 14, 2012 | Stihl Saws
My stihl fs 350 wont start at all now i bought new air filter petrol filter and spark plug kit, still no luck, i messed about with the one screw on the carb so much i dont know where it is supposed to be...
if your fuel was bad, you have oxdashion in the sys. check your spark and compreshion. no less than 78pds if all is good, RR carborator over haul it, no if and or buts. this is an EPA Carb. flush tank line carb and get the oxdashion out. set each screw to 1 to 2 turns out and adjust the idl frist than the high side at full throttal untell engine smothes out
Oct 11, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
368 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
