have older all-in-one stereo system
with dual audio cassettes.
the playback speed on both decks has
slowed so music tapes don't sound right.
is it possible to get inside the unit and
fix the 2 decks?
would these decks be driven by 'belts'
that i could replace?
in most cases yes: each deck probably has a flat belt that has aged and does not offer the correct tension to the capstan drive. all parts that touch the belt must be cleaned with alcohol; the capstan pressure roller probably needs cleaning also. usually have to remove some parts/screws to be able to take out/install the belt. replacement belt must be about 1/2 inch shorter in circumference than what you remove. of course power/batteries must be removed before opening case. be gentle when replacing screws and note the types and lengths as these are removed to make sure they go back in same place - low cost belts available on internet after searching ($1 - 3$)
i have a singing machine is-1028. i purchased a CD-G from Best Buy and when the words are scrolling...
(More)
i have a singing machine is-1028. i purchased a CD-G from Best Buy and when the words are scrolling across the screen the green highlight doesn't stay up with the music. in addition the words get overlapped as the play across the screen. can anyone help???
My Altec Lansing inMotion Portable Speakers for Apple Turn on and will play radio stations...my ipod...
(More)
My Altec Lansing inMotion Portable Speakers for Apple Turn on and will play radio stations...my ipod will play threw its headphones...but when i plug my ipod onto the inmotion speakers it will not play sound??? WHY!!!
