Question about Microwave Ovens
Microwave runs when door is opened and is not programmed to run.
  • 864 Answers
Sounds like a defective door switch.  DO NOT USE UNTIL FIXED!!  Or replace the unit.  Microwave ovens have door switches to prevent operation when the door is open because the microwaves are dangerous to humans outside the unit.  The door and cabinet contain the microwaves when it is operating correctly.
Posted on May 29, 2009
  • 332 Answers
THE CONTACT ON THE OVEN IS STUCK IN, WHERE THE DOOR LATCHES IT'N NOT SPINGING BACK, CLEAN IT OFF, IF NOT YOU NEED A NEW SWITCH
  • Jim Casey Oct 03, 2011
    Great help. Thanks. Squirted electronic/computer cleaner into hole where door locks. Then used Que Tip to clean out gunk and it was good to go. Seems like a weird way to program a microwave. Now 11 year old decent Kitchen unit has more life.
Hey friend, thanks for your post!
From my understanding your Frigidaire microwave is running when the door is opened. I have identified a few possibilities could be the control panel or your door. Since it could be any one of these underlying issues I would recommend having a professional come and properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Fan continuously runs, have to leave door open
Check the door switches with digital meter, usually find one bad one. Set meter to ohms and test, some will be normally open and others closed, check with the door open and closed.
Jun 20, 2012 | GE JVM1850 1000 Watts Microwave Oven
My microwave keeps running....meaning when i close the microwave door it will automatically run.
The timer control has the problem so it need to be replace. But be sure you do not program the microwave to auto run when the door is close some microwave have that feature.
Hope my advice help you.
Apr 04, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
Microwave runs constantly
you have a door inter lock sw/ failure . replace the sw. there 3 .. ir they click there probably good . one of them does not click . primary sw secendary sw . and mont sw . .. a very common problem with all brands of micro's //
Jan 04, 2010 | Maytag Appliances Over-the-Range Microwave...
Microwave is still running when the door is open
The cooling fans run for a time after the magnatrons have stopped, The magnatrons are the heating components so I dont think you are in any danger as the microwave doors are double locked so the magnatrons cant run once the door is open
Sep 27, 2009 | Panasonic Microwave Ovens
Microwave oven runs when door is open, and does not always run.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 27, 2008 | Panasonic NN-C994S Convection/Microwave...
Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | Microwave Ovens
Turntable goes around when the door is open and the microwave is off.
Do not run the microwave with the door open. You will be cooked. Sooner or later, if there are enough microwave ovens, (and there are), everything that can go wrong with them will, eventually. There are several interlocking safety systems built into every microwave so that they won't work with the door open. Yours may have failed. I've never come across one, but that doesn't mean it can't happen.
It may only have a fault making the fan and turntable operate, which can sound like it's working with the door open. Either way, get it checked or get a new one.
This assumes that the microwave isn't actually supposed to do what it is doing under normal conditions or current programming. Refer to manual/instructions if unsure.:::Spiceweasel.au
Apr 03, 2008 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
349 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
