Question about Raypak DOOR ASSEMBLY
Raypak heater won't stay ignited
Just tried turning on the RP2100 for the first time. The spark seems to ignite and start heater. It then turnes off and shortly thereafter reignites again, then turns off, etc. etc.
    Top Expert:
  • Raypak Master
  • 8,163 Answers
Clean flame sensor
Posted on May 25, 2016
3 Suggested Answers
SOURCE: I have a Raypak pool heater the pilot will lite but the unit will
My Rapak gas pool heater burner will not ignite. I changed the flame sensor and then the main gas valve (on a recommendation of a heating contracter) and after spending almost $300 on parts, I may have not needed, it still will not ignite. The water temp has been around 80 using the solar cover but now with the air temp in the 50's at night and only in the 70's in the day the water is a brisk 70 degrees. We would like run the heater now, so we can use the pool for a bit longer this fall.
Any ideas? Some people told me there is a valve that senses the proper amount of water is flowing around the boiler so it doesn't burn up, is this possiblely the problem that the valve is not opening?
Joe Snyder, Toledo, Ohio
Posted on Sep 09, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
How do i fix the spark ignition for super ser F250 Catalytic gas heater ?
you should seriously consider getting a professional to change the ignition
Nov 30, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
What does ILO mean?
Ignition lock out
This happens when a safety feature kicked in and the heater tried to start up again. Turn the power off at the breaker for 10 seconds and try again.
It should fire up or give an error code for possible issues
Aug 04, 2014 | Raypak Rheem RP2100 399K BTU Natural Gas...
What part do i need when plt code comes display ?
spk I think means spark for ignition and plt means pilot so i assume the heater tried to light but the pilot light is not staying on. could be dirtly contact on the ignition spark plug or dirty pilot flame need to be cleaned and the unit serviced.
i hope this was useful.
May 28, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Raypak RP2100 Model P0127NCO spa heater with a problem.
Cycling on/off like that can be a number of things. One of the more common problems is a "flow" problem. Try cleaning out your filter. If it is this type of problem, the flow switch is not sensing proper amount of water flow.
Jan 15, 2013 | Raypak Pool & Spa
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
The raypac 2100 pool heater turn on but when you go to fire it al
If you hear it sparking, verify the spark is happening INSIDE the combustion area and not shorting out at the ignition module. Also verify you actually have gas available and the gas valve is turned on...
Apr 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My raypak rp2100 electronic seems to light the pilot light but then it takes a while to light the gas and when it does it shoots flames out the top of the heater. I'm thinking its the gas valve or the...
It is probably something much more simple than that...Turn it on and stand back until it finally ignites, then look, using a mirror, at the burner tray from below. You will probably find a lot of the tubes, especially those near the pilot area, are not working or are burning bright orange. If that is the case, something, probably spiders, are blocking the gas from getting into the tubes. That will cause the big burst at ignition as the gas builds up for a bit before it finally reaches the pilot area.
Aug 13, 2009 | Raypak Rp2100 Digital 336k Btu Propane...
Raypak DOOR ASSEMBLY Logo
95 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
