How do remove the capacitors from a 50" magnovox paslma tv model#50mf231d/37
  • che_izm May 29, 2009
    The capacitors seem to be in a tight spot. Using the soldering devices and the spray and cream won't demalge the rest of the board?
    Novelist:
  • 151 Answers
First of all the capacitors are located on the main board and power supply board of the tv.to remove the capacitors you should have few tools 1)the hot soldering gun. 2)the soldering iron device. 3)the soldering flux 4)the plier. now the procedure to remove the capacitor is as follows: first of all apply flux cream on the pins of the capacitor which are fitted on the board.oly apply the flux cream on that capacitor pin which you want to remove,not on all capacitors.then with the hot soldering gun spray the hot air on the part of the board where the capacitor is actually fixed.after that with soldering iron device just move the capacitor pins to make it loose.then with the help of plier grap the capacitor and pull it back,it will be removed slowly. the required parts for removing the capacitor will be available at any local electronics hard ware store  or you canm also get this at  www.radioshack.com this will help you. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 29, 2009
  • spark9 May 29, 2009
    no it will not damage rest of the board.but if you still feel risky then.get it removed by a local electronics repair person.as just getting the capacitor from the board will hardly cost any thing.it will be negligible.
    as if a mistake is done whole board will get damaged and short.but the procedure given above is the exact procedure.if you feel confident go for it.otherwise local electronics repair person is advisable.
    thanks please do rate.
I own a magnovox 50 mf2311d-37 plasma tv >when we power the tv on the green light comes on trhen about 3-5 seconds later it goes out and a red light comes on Pleae tell me what the problem is why...
this is a common problem, but it may or may not be a cheap fix. The capacitors that energize the screen go out alot on lcd's,lpasma's, and dlp's. The screen needs a surged charge to energize the screen, and the capacitors due this. Unfortunately, alot of capacitors put into the flat screen type tv's have a low quality set of capacitors in them. They should last for 15-20 yeaer, but alot of tv's capacitors are going out within the first couple of years. If your tv is under warranty, then take it to BestBuy, or Fry's electronics, as they have certified technicians foe this specific repair., If not still under warranty, you can still take it to them, but it may be a costly repair, as a set of high quality capacitors can be quite expensive. Sometimes the repair is more expensive than the cost of a new tv of the same exact size! Just bear this in mind.
Dec 17, 2010 | Philips Televison & Video
Magnavox plazma 50 inch flat screen wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Televison & Video
We have a Magnavox, 50 inch plasma TV, model 50MF231D/37. Recently when the TV is powered off and an attempt to power it back on again has been made, we get a red blinking light. The light blinks six...
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
Dec 10, 2009 | Televison & Video
I need help in identifying whether or not my magnovox is 720p or 1020p. The ID # is 37mf437b/37 and the serial # is bz3a0722610855
Google the model number--owner's manuals are available on the internet for free.
This model (37MF437B/37) IS A 1080P SET.
If you need more information or advice let me know--I am here to help people.
If this helped you, rate this solution as I do this here for free.
SD TECH
Nov 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I had two capacitors in my 50mf231d/37 50 inch plasma tv go out.
your problem is in the Y or Z sustain boards i just fixed one of this today with the same exact problem and i replaced  the Y sustain BINGO.
good luck
caypianan@yahoo.com
May 12, 2009 | Samsung HP-S5073 50 in. Plasma HDTV
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
50" Magnavox Plasma TV will not turn on - Red LED blinking 4x
When you have the red light that blinks four times on the 50" Magnavox Plasma Model 50MF231D/37, you should look for the capacitors on the power board in the center of the of the TV. Look for two 3300uf, 10V, 105c capacitors that have a build up of pressure that has caused the top of the capacitor to look rounded instead of the flat top that will be on all of the other capacitors. Changing these two capacitors fixed the problem of the TV not coming on.
I had more trouble finding the capacitors than changing them. I could not find them locally so I went to an on-line electronics supply store where they were $1.65 each and $8.99 to ship.
Jan 03, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
