Question about Verizon Communications enV2 Cellular Phone
External buttons not working and battery acting up
My enV2 external buttons will sometimes not work right away. I'll have to keep pressing them until they start working again. The worst one is the "ok" button, but all of the others do it, too. Also, when I get to school at 7:40 I shut my phone off and turn it back on at 3:30 after school. My phone has been at three bars of battery power when I shut it off, and when I turned it back on there was low battery and it shut off a few seconds after that. That battery situation has happened twice.
Same with me! My OK and # buttons constantly stop working X-X I just have to hold them down, keep hitting them, or hit them with another button. But usually Ill have to open the phone.
Posted on Jun 04, 2009
My LG ENV2 buttons on the external side will not work
the same thing happened to my env2.....and everyone else that i know who has the env2! i think it is just the phone....i eventually got tired of it and got a replacement
Nov 06, 2009 | Cell Phones
My env2 is having spazes the ok button and the
take this to the verizon repair store nearest you and explain your problem..when mine starting freezing up it was just a download of new software it needed because of a glitch when they first came out.
Aug 14, 2009 | Verizon Communications enV2 Cellular Phone
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
HP laptop does not start.LED on.black screen "warning-battery low
Im not sure but there is normally a button somwhere on the laptop which acts a a reboot button. normally very small and have to press it using a pin etc. You could try that then turn it on but not sure if it will help?
Jun 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
External "ok" button not working, can't access my env2 unless I open it and use internal keypad.
this IS NOT a solution... but for some reason it works for MY INDIVIDUAL PHONE... and i was wondering if anyone can repeat it for me to see if its universal or at least more common than i think it is.
I pressed 9 then # then 0. [like i said.. this is just my phone. im pretty sure if you put another number besides 9 as a first number it would still work..] anyways... when i pressed it and then pressed the okay button... it worked!!
however... i find this to be a little temporary.. it only works for about 24 hours and then it goes back to not working. and of course i redo it and it works.
I HOPE THAT SOMEONE CAN BENEFIT FROM THIS OTHER THAN ME
May 25, 2009 | Verizon Communications enV2 Cellular Phone
Freezing/ screen issues
LET THE BATTERY DIE OUT .. IT';LL TAKE I GUESS ABOUT ONE DAY TILL IS COMPLETELY DEAD THEN EVERYTHING IS GOING BE NORMAL..TRY NOT TO RUSH CLICKING BUTTOMS TOO FAST OR DELETE STUFF FROM YOUR MP3 INSTEAD FROM THE COMPUTER.
Apr 29, 2009 | Mach Speed TRIO Onyx MP3 Player
Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Mar 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
My enV2 has problems
Gosh alright so the front little screen or the inner large screen doesnt work? I'm going through the same thing right now and yeah it really sucks. Taking the battery out does nothing all you have to do is go to your local verizon wireless store and theyll try to fix it or replace your phone
Feb 04, 2009 | LG enV VX9900 Cellular Phone
Front keys will not work on my lg env2
Well the reason that they stop qorking is because when you open your phone up all the way, it tears something in your phone. to get it to work. hold down the okay button. open the phone while you are still holding the okay button, then close it back and release the okay button. it is not a permenant fix but it works for a little while :)
Nov 25, 2008 | LG enV VX9900 Cellular Phone
My camera doesn't turn on at all
It is not turning on maybe it was exposed to extreme temperature that is why it's acting up that way.
First thing to try is to do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Return batteries
- Turn on camera
Make sure to use fresh batteries:
Alkaline batteries (Non-rechargeable) or
Nickel-metal Hydride [Ni-MH] (Rechargeable)
Once your camera turned on, kindly set the battery type option of it properly so there is proper connection between batteries and camera.
To set the battery type:
- Put batteries
- Turn on camera
- Press MENU button
- Scroll to the right until you see SETUP
- Keep on scrolling down until you are in BATTERY TYPE
- Press right button for you to see 2 options like Alkaline or Ni-MH
- Select the batteries you are currently using
- Press MENU/OK for changes to be saved
- Get out of those by keeping on pressing MENU
- Turn off camera for 10 seconds for settings to be refreshed
- Turn it on and take pictures
* If it still does not work, send the camera for repair.
Call the hotline of your camera's manufacturer so
they could provide with how you could safely send your camera.
Jan 16, 2008 | Samsung Digimax S500 Digital Camera
Verizon Communications enV2 Cellular Phone Logo
168 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
