Question about Dryers
Maytag Atlantis MDG7600AWW Not Heating
I have a six year Maytag Atlantis MDG7600AWW gas dryer.  The dryer is not heating to dry the clothes.  It took over three hours for the clothes to tumble dry.  When I opened the door, the clothes were dry but cool.
I cleaned the vent thoroughly and made sure the vent was secure to the outside vent and also to the dryer.  I tested another load.  The dryer was working properly.  There was heat!  However, a few minutes later, it no longer was heating.
I went behind the dryer again.  I disconnect the vents and resecured them.  It heated for another five minutes and then that was it.  I am stumped on this.  Any assistance in this matter is greatly appreciated.
The setting was on regular not air fluff.
Regards,
Daryl
  • 3 more comments
  • dj2969 Oct 30, 2007
    Here is an update:
    I could not find any gas coils.  I have what appears to be a 'glow' plug which turns on orange and then kicks on the gas/blue flame.
    I vaccumed off all of the lint on wires and within the sheet metal cylinder in which the gas operates.
    The gas/flame will run for about 10 minutes and shut off.  I will not return on after the glow plug light up.  What I have done, is let the dryer stop running for 15 minutes and then turn the dryer back on.  The cycle will begin once again for about minutes.  It takes over 2 hours to dryer damp clothes.
    Could it be a timer?  A heat sensor?  There are no obstructions in the in dryer vent.  I have exhausted any other work around with the dryer.
    Any assistance or advice is greatly appreciated!
  • Anonymous Feb 01, 2008
    I have exactly the same dryer same model and same problem.Did u ever fix your dryer? I have a service tech came in and take a look at it, but he was blaming it on the vent.changed the vent didn't do anything at all still not heating up.I opened up the dryer and what i can see is that the heat doesn't stay up it dies out after a few minutes...Please I need some advice and help desperately....
  • dj2969 Feb 01, 2008
    Yes, I did not fix my problem and it has been running perfectly for the last three months.
    My issue was lint contacting the coils. The coils would fire up and then automatically shut down. I removed the bottom panel and carefully took the vacation nozzle with a soft brush and removed all lint from the coils and the stainless steel compartment. After that, I vacuumed around the entire interior of the base of the dryer to capture any remaining lint.
  • Anonymous May 11, 2009
    Same dryer but I'm not getting any flame at all.
  • Anonymous Mar 24, 2014
    Dryer spins and is venting fine
  • 164 Answers
The gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Posted on Oct 23, 2007
I have exactly same model and same problem, did u ever fix your dryer?? Desperate for help....
Posted on Feb 01, 2008
My dryer will not heat.....the drum spins and air appears to be blowing but not heating up to dry clothes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Aug 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Dec 29, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Jun 14, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Dryer not heating up
you need to be getting at least 220v to the terminal block, if you don't check recepticle and the breaker
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
May 19, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
2,195 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
