Question about Whirlpool Duet GHW9150P Front Load Washer
Need bolts to stabilize washer for move
The bolts that came with the washer were not re-useable and i need to purchase new bolts to stabilize the washer while being moved to another state.
  • 90 Answers
Dont know if you can purchase these. First people to try are the manufactures. Otherwise, unscrew the two screws at the rear top of machine and pull backwards to remove top.Then pack some towells or rugs around the drum then replace top. Don,t forget to remove rugs at new home.!! Good luck on your move.
Posted on May 29, 2009
While in the process of moving a washer and dryer, do the drums need to be stabilized? If yes, how?
When you are moving either a washer or a dryer you do it carefully.
Other than that, you don't need to stabilized the drum.
Oct 16, 2013 | Kenmore Washing Machines
What does the control arm on the front left driver side supposed to look like fully assembled
Hello! First diagram is the lower...Second is the upper..Guru...saailer
LOWER IDENTIFICATION:
Item
Part Number Description 1
5495 Stabilizer Bar Link Bolt and Bushing Assembly 2
18A192 Nut, Washer and Bushing Assembly 3
808264 Bolt 4
5005 Frame 5
5B326 Torsion Bar (LH) 6
5B327 Torsion Bar (RH) 7
620481 Nut 8
5C491 Nut and Washer 9
3079 Front Suspension Lower Arm (LH) 10
3078 Front Suspension Lower Arm (RH) 11
3A130 Tie Rod End 12
808166 Nut 13
808167 Nut 14
5K483 Front Stabilizer Bar Link 15
5482 Front Stabilizer Bar 16
5484 Front Stabilizer Bar Bushing 17
3B353 Front Stabilizer Retainer 18
N807396-S100 Bolt A
- Tighten to 40-55 Nm
(30-40 Lb-Ft) B
- Tighten to 150-200 Nm (111-148 Lb-Ft) C
- Tighten to 21-29 Nm
(15-21 Lb-Ft)
UPPER IDENTIFICATION:
Item Part Number Description 1 3C156 Damper Assembly (RH) 2 805348 Nut and Washer 3 - Shock Absorber Insulator
(Part of 18198) 4 3C157 Damper Assembly (LH) 5 3020 Front Suspension Bumper 6 3083 Front Suspension Upper Arm Assembly A - Tighten to 34-47 Nm
(25-35 Lb-Ft)
LOWER DIAGRAM FOLLOWED BY UPPER:
Feb 12, 2012 | 1996 Ford Explorer
Front stabilizer arm has come loose on drivers side could bolt head be worn off? does bolt screw uup from bottom through stabilizer arm?
The stabalizer bar is connected to the lower control arm with a stabilizer link. It sounds like the link has gone bad from your description. You can purchase a new link kit from your local parts store. You will assemble the new link starting at the control arm and working your way to the stabilizer bar with the threaded end of the bolt going through the opening on the bar. Good luck and thank you for using fixya.com!
Oct 20, 2011 | 1996 Chevrolet Blazer
Do i need to put in shipping bolts to move my washer 600 miles and if so where do they go and what size bolt do i need?
The shipping bolts protect the washer tub from getting bounced around when the washer is moved. The shipping kit should have come with your washer when you purchased it. If you have misplaced it, you can find it here http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF2940ES-%3d%3di1170681&PartID=1170681
Hope this helps you.
Aug 31, 2010 | Frigidaire GLTF2940ES Front Load Washer
How do you replace ball joints
Removing the Ball Joint Step 1 Loosen the lug nuts on the front wheel assembly with the ball joint you need to replace. Do not remove the lug nuts.
Step 2 Set the transmission in neutral (manual) or park (automatic) and raise the wheel off the ground using a floor jack. Then support the car on a jack stand.
Step 3 Chock the rear wheels and apply the parking brake.
Step 4 Remove the wheel lugs and the wheel assembly.
Step 5 Remove the mounting nut and dished washer that secure the stabilizer bar to the control arm. Use a wrench or ratchet and socket.
Step 6 Unscrew and remove the mounting bolt and nut holding the inner side of the control arm to the car's body. This will relieve the tension on the stabilizer bar. Use a wrench to hold the mounting bolt as you unscrew the nut with a wrench or ratchet and socket.
Step 7 Unscrew the bolt on the steering knuckle that holds the control-arm ball joint to the knuckle. Use a wrench or ratchet and socket.
Step 8 Spread the steering knuckle joint that holds the control-arm ball joint to the knuckle. Use a large screwdriver or pry bar. Then separate the ball joint from the steering knuckle.
Step 9 Pull the control arm from the stabilizer bar.
Step 10 Remove the stabilizer bar spacer from the control arm and keep it in a secure place. You will need to use it on the new control-arm ball joint assembly.
Installing the Ball Joint Step 1 Insert the new control-arm ball joint stud into the steering knuckle joint. As you look through the mounting bolt hole on the steering knuckle, align the notch on the ball joint stud with the hole. Insert a new ball joint mounting bolt and start a new nut on the bolt. Tighten the nut.
Step 2 Mount the stabilizer bar spacer in the control arm, then insert the stud bolt at the end of the stabilizer bar into the control arm mounting hole and spacer.
Step 3 Set the other end of the control arm in its mounting position and insert the mounting bolt. Then start the mounting nut on the bolt by hand.
Step 4 Hold the head of the mounting bolt that secures the control arm to the car's body using a wrench, then tighten the nut.
Step 5 Secure the stabilizer bar to the control arm with the dished washer and mounting nut. Tighten the nut.
Step 6 Install the wheel assembly and lugs. Tighten the lugs with the lug wrench just enough to hold the wheel assembly firmly in place.
Step 7 Lower the vehicle and finish tightening the wheel lugs.
Step 8
Remove the chocks from the rear wheels.
Aug 08, 2010 | 1998 Ford Escort
Replace swaybar 1999 silverado
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the tire and wheel.
  3. Remove the stabilizer shaft nut from the link bolt.
  4. Remove the stabilizer shaft link bolt.
  5. Remove the stabilizer shaft link insulators and spacers.
  6. Remove the oil pan skid plate, if equipped.
  7. Remove the stabilizer shaft insulator bracket bolts.
  8. Remove the stabilizer shaft bracket.
  9. Remove the stabilizer shaft.
  10. Remove the stabilizer shaft insulators.
  11. Inspect all of the parts for wear and damage.
To install:
  1. Install the insulators to the stabilizer shaft.
  2. Install the stabilizer shaft.
  3. Install the brackets over the insulators and the stabilizer shaft.
  4. Install insulator bracket bolts and tighten to 37 ft. lbs. (50 Nm).
  5. Install the stabilizer shaft link insulators and spacers.
  6. Apply Loctite® on the threads of the stabilizer link bolts then install the bolts.
  7. Install the stabilizer shaft nut to the link bolt and tighten to 89 inch lbs. (10 Nm), and continue to tighten the nut until 2-4 threads protrude above the nut.
  8. Install the oil pan skid plate, if equipped.
  9. Install the tire and wheel assembly.
  10. Remove the safety stands
  11. Lower the vehicle.
Mar 30, 2010 | 1999 Chevrolet Silverado 2500
Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Sep 18, 2009 | Asko W6461 Front Load Washer
Front Sway bar(Stabilizer bar)
please give good rating if this helps
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise vehicle on a hoist. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Remove and discard nuts retaining stabilizer bar link (5K484) assembly to front stabilizer bar (5482) and front shock absorber (18124) with an 8 mm closed-end wrench and an 18 mm open-end wrench.
  1. Remove nuts retaining steering gear (3504) to front sub-frame, and move steering gear off the front sub-frame.
  1. With another set of support safety stands under front sub-frame, remove two rear subframe retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar U-bracket bolts and replacestabilizer bar brackets and/or front stabilizer bar as required. Discard lower suspension arm stabilizer bar insulator (5493) and bolts.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar insulator installation position.
  1. Lubricate inside diameter of new lower suspension arm stabilizer bar insulator with Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber lower suspension arm stabilizer bar insulators.
  1. Install new lower suspension arm stabilizer bar insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on front sub-frames and install new bolts. Tighten to 30-40 Nm (22-29 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Position steering gear onto front sub-frame and install retaining nuts. Tighten to 115-135 Nm (85-99 lb-ft).
    Install stabilizer bar link to front shock absorber and to front stabilizer bar, making sure that the stabilizer bar link is properly positioned. The letters "Top LH" and "Top RH" are moulded into the stabilizer bar link for correct assembly to the front shock absorber strut.
  1. Install new nuts and secure stabilizer bar link assembly to front stabilizer bar and front shock absorber. Tighten to 77-103 Nm (57-75 lb-ft) at front shock absorber strut and 47-63 Nm (35-46 lb-ft) at front stabilizer bar.
  1. Remove safety stands.
  1. Lower vehicle.
Apr 11, 2009 | 1995 Ford Taurus
Need to move front loading washer, how do i stabilize it to avoid damage in moving
order the locking pins that are inserted into the back to keep the drum set. Call the store you bought it from or a local mover to purchase.
Mar 26, 2009 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
905 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
