Question about Maytag Neptune MAH9700 Front Load Washer
Front load washer not spinning correctly
We recently bought a maytag neptune front load washer model mah9700aww. we have it leveled, on stable floor and when it starts to spin it will start shakin' across the floor now codes for being unbalanced either. once it starts spinning it will start the shaking and then stop spinning. any suggestion on what the problem might be. tammy My washer seems to be off balance and often bounces across the room. Now the spin cycle keeps getting cut short and I get an error message, but cannot get it clear even with little or no clothes in the machine. This has happeened to 2 other family memebers also. What is this problem?
  • 1 more comment
  • mareliserobi May 30, 2009
    Now the washer door will not unlock. The washer stopped halfway through the cycle. Is there a way to manually unlock the door?
    I pulled the washer out to gain access to the back. There is no cancel button or spot to insert something in it to manually unlock. Where should I be looking for the cancel button or spot in the back?
    I got the door unlocked. Thank you. Only problem now is that it still will not run through a rinse and spin only cycle. I have unplugged it for a few hours to see if the machine will reset itself.
  • 332 Answers
IT SOUNDS LIKE THE PAKING STRAPS MIGHT NOT HAVE BEEN FULLY REMOVED, OR THE HAS BEEN A SMALL CLOTHING ITEM THAT SLIPPED THRU THE OPENING WHEN YOU OPEN THE DOOR THERE IS A SEAL AND IT IS VARY FLEXABLE SOMETHING COULD HAVE GOT THRU, BUT IT STILL SOUNDS LIKE THE PACKING STRAP WAS NOT REMOVED ALL THE WAY IT COULD HAVE BROKE OFF WHEN BEING PULLED OUT, IT'S JUST A PLASTIC STRAP BUT MIGHT HAVE TO REMOVE THE FRONT COVER TO GET TO IT,
Posted on May 29, 2009
  • 2 more comments
  • gary miller
    gary miller May 30, 2009
    unplug the washer, then plug it back in see if it resets if not push the cancel button it will drain the water and you should be able to open the door, there should be in the manual about this also, in the back of the washer there should be a spot to be able to unlock it by inserting something in it, try the cancel button first
  • gary miller
    it also sounds like the strap is in the washer and has now locked it up, you might want to have the company you got it from come out and get it out
  • gary miller
    there is not a cancel button on the front control panel
  • gary miller
    the on off button hold it in it might cancel it
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag mah9700aww,will not spin(laundry soaking wet)
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
,.,./l;
Mar 05, 2011 | Maytag Neptune MAH9700 Front Load Washer
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH9700AWW - no power to pump.
Check water level switch, pump motor relay that activates the pump.
Apr 06, 2010 | Maytag Neptune MAH9700 Front Load Washer
My Neptune washer (brand new) "walks the floor" during the spin cycle. How do I correct this?
Try to get it completely level and with all four feet firmly on the floor. If it's resting on three feet and/or not level then this is what will happen. The feet should be threaded so you can adjust them easily.
Aug 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
Feb 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I had the same problem, once I remove the shipping bolts on the back of the machine it worked fine.
Feb 01, 2009 | Maytag Neptune MAH9700 Front Load Washer
Mah9700AWW maytag washer dooer is locked
unsrew the lid to soap dispenser and search for the cord , you probably have a bad wax motor(lock motor)
May 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
313 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
