Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
NO FORWARD NO REVERSE
I RECENTLY PURCHASED A CRAFTSMAN GARDEN TRACTOR 6500 26 HP KOHLER ENGINE 48'' DECK. IT WILL NOT MOVE FORWARD OR REVERSE . I TRIED TO PURGE THE TRANS BUT TO NO AVAIL.
  • garyv707 May 11, 2010
    THANK YOU FOR YOUR INQUIRY, HOWEVER WITH THE ASSISTANCE OF MY LOCAL SEARS REP I WAS ABLE TO FIX THE PROBLEM. THE DRIVE BELT HAD SLIPPED OFF OF THE IDLER PULLY. SINCERELY : GARY VETTER
  • Dwain Pippen May 11, 2010
    Just a couple of simple things to rule out. You do have the lockout rod on the rear disengaged, right? That's the rod that you pull out and hook so you can roll it. Secondly, have you removed one of the rear wheels?
    Problem Solver:
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
Posted on Aug 09, 2009
My craftsman yard tractor all of a sudden will not move, 42 " cut , 15.5.hp kohler motor Hydrostatic drive ,!
bypass rod pulled out to allow pushing the tractor, the noise is the hydrostat bypassing fluid (normal) if my crystal works
Apr 01, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
Type of oil to use for my Craftsman 24 hp riding lawn tractor
Hello, if you have a Kohler engine you would use any 10w30 oil, but if it is a Briggs & Stratton you would use SAE HD30 oil. Either can be purchased from your local auto parts store. When you refill be careful to not over fill. Use the dip stick to ensure you have the proper oil level. Over filling will cause the engine to smoke under load or possibly blow out a seal. Good Luck!
If this was helpful, please vote yes. Thank You!!
Apr 09, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower starts, but won't move
I would first look at the drive belt for damage or to see if it has derailed.
May 16, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 24 hp 42 in. Deck Yard Tractor problem. won't move forward. belt is fine.
the gears inside rearend are bad either sheared the key inside or the spider gears have teeth missing
Nov 10, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Transmission won't engage
My Craftsman 24 hp twin 42in cut motor runs ok as well as the lawn mower. However will not move forward or backwards something is not connecting.
Sep 21, 2008 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
498 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
