Question about Motorola Computers & Internet
Motorola sbvs220 Ok I got new computer i want to hook it up to existing network by added a router Lynksys BEFSR41 ( worked at previous location). When ever i plug the router up to modem and new computer it says limited connetivity. It doesnt allow my new computer to renew IP address.
    President:
  • 623 Answers
Make sure that your router and computer are set to get their IP addresses via DHCP.
Either the router is not setup as DHCP server or your computer has a static IP address assigned which conflicts with the router settings.
Do you have cable or DSL service (in which case the router should be set to PPPoE)?
If you have cable service, just reset the router to factory default by pressing the reset button on the back for about 30 seconds.
Then go to your computer and
  1. Go to Control Panel -> Network Connections.
  2. Right-click your Local Area Connection and choose Properties.
  3. Scroll down and double click on Internet Protocol (TCP/IP).
  4. Make sure that all settings are set to Obtain ...automatically.
Click OK two times (the second time takes a little bit longer, because the settings are applied.
If you have any more questions or need help with the settings, just come back here and leave a comment - I'm happy to help.
Posted on May 30, 2009
I set up my lynksys befsr41 ver4.1 using the set up disk. I hit enter at the password window and it goes to analyzing my computer. Then the password window shows up again etc. etc. etc. At the lower left I...
Are you trying to install the router.
You can do it manually without the CD.
First reset the router for 30 seconds. unplug the power to the router. wait for 5 seconds. Plug it back in.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How do i install my new belkin systyem when ive
yes you can use it.
first connect your Belkin router to computer with lan cable .
Then access it wityh this link.
http://192.168.15.1
user name as "admin" and password as "admin"or
blank or
"password"
then configure your router as your old lynksys settings.then save settings and restart .
Aug 22, 2009 | Belkin N1 Vision Router
Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Apr 14, 2009 | Linksys EtherFast Cable/DSL Router
2210 modem to befsr41 router connectivity
HI
JUST GO TO THE SETTING OF ONE OF THEM AND CHANGE THE DEFULT GATE TO CHANGE THE THIRD NUMBER BY ADDING ONE OR SUB. ONE
Dec 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
NIC blinks on then off for longer run lines
You need to update the firmware of the router then hard reset it.
Download the router's firmware at www.linksys.com/download
After updating the firmware, you need to hard reset the router.
Press the reset button at the back of the router for 30 seconds then unplug the power for 30 secs then plug it back in. That should fix it.
Jul 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Have an Acer Aspire PC computer - trying to hook up a Lynksys nr041 router so can hook up another HP Notebook computer...not for sure how to do this and be able to use internet on both computers. Thanks...
Ok if you have DSL this router will NOT connect via PPPoE so no user name or passwords for dsl. But if you have a cable modem just plug the network cord from your cable modem into the WAN port on router... then plug the computers into the 1-4 ports on the router.. you might need to reset your Cable/Dsl modem after everythings hooked up.
May 02, 2008 | Linksys (NR041) Router
Blinky...
the solution buy another router you you can use other cp
Apr 14, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lynksys is causing high blood pressure
Hello cyndilynn
OK, my friend, don't fret. Let's find out what the skinny is. First things first...
(01) Do you have the manual for your router?
If not, you can download it from HERE.
(02) Do I understand you correctly that you are able to connect to the Internet from one of your computers and not the other WHILE using the Linksys BEFSR41 router?
Some points to clarify:
(A) Your Linksys router (connected between your cable or DSL modem and your computer(s)) and your Linksys NIC (installed in your computer) are two different animals that serve different purposes.
(B) Your router should be connected to each of your computers via "straight through" (not "cross-over") Ethernet patch cables that run from the LAN ports at the back of your router to a NIC connection on each of your computers.
(C) The NIC and the ROUTER do not have to be made by the same manufacturer (in this case Linksys). Manufacturer's NICs and ROUTERs can be mixed and matched just fine.
I suspect the issue is w/ detection of your NIC on one of your computers. I doubt the issue has anything to do w/ your router.
If that is the case, please, provide details about the two desktop computers that you have tried the Linksys NIC in (one successfully, one unsuccessfully).
(03) What operating system is each computer running?
(04) Has the computer that you have been unsuccessfull connecting to the Internet through the Linksys router ever been successfully connected to the Internet?
For now, please, answer these 4 questions and provide any other information you can think of (the more details the better). Then we'll move on to the next step.
Thank you
BJ
Apr 04, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Chris
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Wireless router
nee dto buy new pci wilress card be your best bet ok
Feb 11, 2008 | Computers & Internet
Computers & Internet Logo
271 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
