Question about Maytag Neptune MAH5500B Front Load Washer
Washer not finsihing spin cycle and bounces across room
My washer seems to be off balance and often bounces across the room. Now the spin cycle keeps getting cut short and I get an error message. I cannot get it to clear even with little or no clothes in the machine. This has happeened to 2 other family memebers also. What is this problem?
  • Anonymous Mar 30, 2014
    the machine bounces around the room
    Brigadier General:
  • 8,619 Answers
Hi!
The noise could be from loose lower front weight mounting bolts or a loose bolt securing
the driven pulley. Check the belt for a weak seam and replace if necessary. Check the motor adjustment bolt for tightness.
"Ticking or Knocking" Noise In Spin: The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the topcover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Usually felt on the backside of the belt as a "flat" spot. Replace the belt.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 29, 2009
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Spin Cycle - washer starts bouncing around room even though level
There are about 6 pairs of springs to hold the bottom tube to the bottom chassis. If some of these came off from designed positions, the tube won't be in balance then the washer starts bouncing off. Make sure these pairs of springs in place then you have no problem.
Sep 15, 2009 | Washing Machines
Need to balance washing machine drum
The drum should not need balancing, but the washer should be level in all directions. If the washer is level, but vibrates excessively during spin cycle, you may need to replace the springs. There is a set of suspension springs which act as shock absorbers. When these wear out the washer will bounce across the floor unless the clothes are 100% balanced in the washer.
Jul 29, 2009 | GE Washing Machines
Front load washer not spinning correctly
IT SOUNDS LIKE THE PAKING STRAPS MIGHT NOT HAVE BEEN FULLY REMOVED, OR THE HAS BEEN A SMALL CLOTHING ITEM THAT SLIPPED THRU THE OPENING WHEN YOU OPEN THE DOOR THERE IS A SEAL AND IT IS VARY FLEXABLE SOMETHING COULD HAVE GOT THRU, BUT IT STILL SOUNDS LIKE THE PACKING STRAP WAS NOT REMOVED ALL THE WAY IT COULD HAVE BROKE OFF WHEN BEING PULLED OUT, IT'S JUST A PLASTIC STRAP BUT MIGHT HAVE TO REMOVE THE FRONT COVER TO GET TO IT,
May 29, 2009 | Maytag Neptune MAH9700 Front Load Washer
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Spins so harder washer walks across the room. the washer is level. the load is balanced. is it the tub inside the washer that is not level
Engage your lid switch so that washer will spin in spin cycle and watch it spin. At end of cycle when washer shuts down the tub should come to a fairly sudden stop if it doesn't then you need to have the brake worked on. If it does post your model number and i'll advise further.
Mar 11, 2009 | Roper RAS8445KQ Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
168 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
