Question about Elan E-948-CB / E-948-CW Oven
Elan 948 OVen doesn't heat and light designating heating does not go on.
The light that signifies heating does not work and the oven does not heat. However, the function selector control does work as does  the light associated with it.
We just had the same problem with the same oven. pull the oven out of the wall. on the top right side there is a fan. there is a safety switch that is activated by the fan blowing on it. a piece of insulation was preventing the switch from activating so the oven thought the fan was not running. remove the insulation and the oven comes back to life.
Posted on Jan 21, 2008
SOURCE:
Hook up to 240 volt branch circuit
VERY strange. Can you find a schematic on the side of the oven for any clues?
Jan 18, 2018 | Elan E-948-CB / E-948-CW Oven
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
TOP OVEN WORKS OK BUT BOTTOM OVEN DOES NOT HEAT UP
There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
Heating Element is Broken
This is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
Hope this help in solving the problem.....
May 17, 2011 | Ovens
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
After light cleaning-Electrolux Ew30ES65 upper oven won't heat now! The bottom oven works fine, the lights are all on, the convection fan works in the upper over but the heating elements don't heat now....
I had the same issue with my EW30EW55GS. This is the second time! The dirst time, the technician replaced all the circuit boards (took a month to get the parts). I figured, I would try a light cleaning again. SAME THING! Again, I'm without an oven for no telling how long. The oven looks great, but don't be fooled - it's a piece of junk!
Apr 04, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Can't turn oven on or set temp
If it has a timer, make sure it is set to manual and not auto, as it will not work in auto mode.,
Plz rate solution.,Thanks.
Dec 25, 2008 | Elan E-948-DB / E-948-DW / E-948-DS...
Control knobs
Hi, Elan oven has seemed to drop off the earth right now but I have some feelers out trying to get parts for it. If you have a manual there may be a # in there to call. The oven itself may have a phone number or a company name to call for information on parts. The best way to fix your problem would be to replace the knobs with new ones. You may be able to take the ones you have to a parts place and they may have something to at least work temp until you get new ones. I will continue to work on finding parts for it so If you find anything or have any information to help me find them, Let me know. Hope I can help. kstfas
Sep 19, 2007 | Elan E-948-DB / E-948-DW / E-948-DS...
Slow warm up
hi petrich let me know if you had your voltage to the oven checked. is must be the problem to have two ovens slow to heat up... let me know..krazytech
Aug 25, 2007 | Elan E-948-DB / E-948-DW / E-948-DS...
Ovens Logo
253 people viewed this question
Top Elan Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Elan Oven Expert? Answer questions, earn points and help others
