Question about Sony Playstation 3 (PS3) Console
PS3 NO VIDEO/AUDIO output- no display NOTHING NEED HELP!!!!!!!!
I have a 80gb ps3 that doesn't show any video or has no audio what so ever. i tried the hdmi and av plugs. yes, they were on the right channels and yes, i tried different televisions and wires. i also already tried holding down the power touch for 5 seconds. the power supply is working fine. pretty sure i cant send it in because i bought it used, the warranty sticker still is on. and don't know if still have warranty . so, someone that know what is wrong. does need new motherboard? where can i buy ONE? Same problem no audio or video and controler blinks
  • 25 Answers
I had the same problem you need to un plug the entire system and let it sit for a couple hours and it workd fine and ever sience that happened its been working fine now. ope that works
Posted on May 29, 2009
I opened the ps3 to clean it. Powers up but no video or audio...
it sounds like you may have unplugged one of the ribbon cords in the PS3. take it back apart and check all of your connections and make sure they are all tight.
Aug 09, 2009 | Sony PlayStation® 3 (80GB) Console
Blu ray movies do not play
Have you checked your video output for the bluray to make sure it is set properly? You should be able to set it to automatic so it will be able to set the signal at the proper level. It also wouldn't hurt to try a lens cleaner which is for the Bluray and ps3 system. (approx $25 at BestBuy)
May 03, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 has no video
I would first try changing the inputs if there is an HDMI cable connected the PS3 will detect it and change the output to HDMI. Make sure when you connect any HDMI cables that the power is off on ALL Units that are using HDMI. Connect the cables then power up all units. Change TV and Receiver or Amp to correct HDMI Inputs. On the PS3 go to Display Settings over to the left of the Crossbar. Select output settings and select HDMI and everything after select AUTOMATIC! Then Set your Audio (Also use Auto) and Save by pressing X.  Good Luck!
Apr 29, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 start up promlem
so if you have ever had your ps3 connected to HDMI (HD cable) before, and your forgot to change it back to the normal cords that came with the game (yellow, white, and red) then you will have to connect it back up to the HDMI and go to the Display Settings and change your video output to the one that came with the ps3 (which looks like just one yellow in the settings.) then after you do that then the screen might go black if your HDMI and regular cable are on a deffirent channels, so you turn to the channel that the yellow white and red cable needs to be to, then it will show the screen and ask you if you want to leave it at this setting with this video output/cable then you say yes then your good to go.
Oct 09, 2008 | Sony Playstation 3 (PS3) Console
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
PS3 MOTHERBOARD-NO video output? need a lot of help!!!!!!!
OK wow stop.....
PLEASE STOP AND READ THIS BEFORE YOU BREAK OPEN THE PS3!!
Did you try and reset it?
Push and hold the power button down when the system is on standbye until it beeps at you.. try this several times it may just neeed to be reset try it and let me know
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
I have a friend at playstation and when I called I had no video or audio using the AV Multi Out.
The soultion is:
1. Turn Off in back (wait few seconds for it to re-set)
2. Turn on in back
3. Turn on in front and hold your finger on it 'till it turns off again -
(you get the beep on then the three beeps for reset and it will eventually beep again and turn off)
4. Turn off in back (wait few seconds for it to re-set)
5. Turn on in back
6. Turn on in front hold finger for three beeps and damn it works!
I was so Pissed for two days and spent $80.00 on new cables (that I did not need) and the answer was so simple.. The SONY on-line troubleshooting instructions really need to be updated!
Let me know if this works for you!
Thanks
Mike M
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
453 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
