Question about Dell A920 InkJet Printer
Prints red and black text on envelopes only
Installed updated driver.
Check MS word settings etc.
Quite simple - select 'print in black and white' from the printer properties.
Posted on Dec 01, 2007
  • 42 Answers
Rollback to the old driver.
Posted on Oct 22, 2007
Ink is smudged on envelope. How do I stop that from happening?
i bet you're printing in Black,
what happens is when black is selected, the 3 colored drums lift up 2 mm annd only the K drum is engaged, amd there is no static in the transfer belt under the CMY drums.
envelopes have air in them and can bounce along the bely after the black has printed, and seeing the toner is powder and not yet fused on, the toner touches the cyan drum as the envelope hits the fuser entry point as well as dragging on the Left transfer belt Blue lift handle(take out the belt and spring the handle off).
If you open the lid in this print mode, and lift out the cyan drum, turn it over and pull back the cover for the OPC drum, you will see the black toner on the green drum.
FIX 1. In the art work place a tiny dot of yellow. this will run the print mode in color and enagage all the drums. gaurantee your print will be fine, and know one ever sees that yellow dot.Problem is, this then runs down your CMY drums for black only printing.
FIX2.
If you have a later machine, downlaod iQueue from Xante.com (free) fantastic software. and get the machine updated with the latest X1.11 firmware from your dealer.
This allows with iQueue, to set the machine to print Black only, and you run the machine without the CMY drums installed....it works, it's great...
Aug 10, 2010 | Xante Ilumina Digital Color Press Printer
Tip
How to conserve color ink when printing only text documents.
First, make sure you have an updated driver installed in your computer. Visit http://support.epson.com for updated drivers.
To select black ink only mode and conserve color ink when printing only text documents, please do the following:
1. Open the Printers window by following the appropriate steps for your operating system:
In Windows 2000: Click START > SETTINGS > PRINTERS.
In Windows XP: Click START > CONTROL PANEL > PRINTERS AND FAXES or PRINTERS AND OTHER HARDWARE. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear.)
In Windows Vista: Click START > CONTROL PANEL > HARDWARE AND SOUND > PRINTERS.
2. Right-click on your printer name and select PRINTING PREFERENCES.
3. Click the ADVANCED tab.
4. Select the BLACK INK ONLY option.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
Ink cartidges are all installed and registering ok. New balck ink installed but will only print in colour and not black print what can I do as I need docs printed urgently?
Does it take (pull up the paper) in the paper? If so, Try to print only images and check if it works or not. It'll be much easier if you let us know the program from which you are printing. Also try to print only in text using Ms Word, wordpad or notepad. If possible update your driver. Good luck.
May 26, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Envelopes print in color and I want black only
First you need to change the settings in the software you are trying to print the envelope. Open the program (for example MS Word), go to the option from which you print envelopes and labels. Set the font color to black, not "automatic", and in Word, click "default", which sets the color as black rather than allowing the printer or its software to select the wrong color. Then try to print on the envelope and let us know if you are able to print the envelope in black only.
Apr 20, 2009 | Office Equipment & Supplies
Won't print envelopes in black
Apr 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
Printing an envelope in cs3 on an epson stylus photo r1800
You can try using Microsoft word in printing on envelopes, it is easier. On my MS word>tools>letters and mailings>envelopes and labels>click on feed and use the fourth from the left option.
Load the envelope at the right side of the printer> the envelope flap should be on the left facing the printer.
Jan 25, 2008 | Epson Stylus Photo R1800 InkJet Printer
Regarding printing of envelopes.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=439428&productBigSeriesOid=14924&spid=439320&pname=HP+LaserJet+1020+Printer&opname=HP+LaserJet+1020+Printer&pname_desc=HP+LaserJet+1020+Printer&st=1&ptype=consumer&stype=pn&qry=printer+doesnt+print+the+first+time&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+1020+Printer&cqry=&uqry=
Oct 20, 2007 | HP LaserJet 1020 Printer
Addresses for envelopes print in red
check your printing preferences in the driver properties for the brother.
Jun 22, 2007 | Lexmark Pro X125 All-In-One InkJet Printer
Printer
This would depend upon the software you wish to use. For instance MS Word has an envelope printing utility built in. Access it through TOOLS > LETTERS & MAILINGS > ENVELOPES & LABELS, use the HELP feature to read help info on the settings required. If you wish to use a simlple text editor like Word pad, simply set the PAGE SETUP settings to reflect the media you are using; for instancce set paper size to ENVELOPE C5, and then the margins to something like Left = 60 Right = 100 Top = 80 Bottom = 50 Click OK and this will then mean when you print your document the text will be kept toward the center of the envelope. Change the envelope and margins to whatever suits you best. Slip the envelope into the printer (face up and flap to the bottom) and push the guard up. You should be good to go.
Mar 27, 2007 | Epson Stylus Photo R220 InkJet Printer
Dell A920 InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
