Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
What's the best buy wireless router out there?
I want to purchase a wireless router with a range of at least 30 ft. Any recommendations?
  • eddie235 May 29, 2009
    I bought a WRT110 last week. The firmware did not work. I am returning it today. Is the WRT400 pretty easy to install?
    Guru:
  • 523 Answers
The below are the model type, Size and the pricing in the market
1. LW6005A----Pure Networking™ 802.11g Wireless Router (1 WAN Connection, 4 LAN Connections)
1.2"H x 7.4"W x 4.2"D (3 x 18.8 x 10.7 cm)
$152.9
LW6005A
LW6005A
2. LW6200A-R2--- Pure Networking 802.11g Wireless 2.4-GHz Antennas, 8-dBi Omnidirectional
0.7"W x 24.8"L (1.8 x 63 cm)
$263.9
3.LW6201A-R2--- Pure Networking 802.11g Wireless 2.4-GHz Antennas, 8-dBi Omnidirectional
9.4"H x 9.4"W x 2.8"D (23.9 x 23.9 x 7.1 cm)
$263.9
4.WL-530g-----1.75′ L x 5.25′ W x 1.2′ H
$£44.95
5. LW6005A----Pure Networking™ 802.11g Wireless Router (1 WAN Connection, 5 LAN
Connections)
1.2"H x 5"W x 3.6"D (3 x 12.7 x 9.1 cm)
$103.9
Regards,
Ayyasam
Posted on May 29, 2009
  • AYYASAMY KASIRAJAN May 30, 2009
    Hi Friend,
    Its easy to install.Just u can easily assign the ip address and start ur network connections.
    Regards,
    Ayyasam
  • 749 Answers
N is the way to go, then it depends what extra features you need...here is a good all-around wireless router http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4629787&CatId=2668
Repost here if you have more questions..
Regards
  • Jeff Strader
    Jeff Strader May 30, 2009
    Easy to use and set up
How can I boost the signal of my AT&T 2WIRE router/modem?
You can increase the range of your router but you need to purchase another wireless switch. What you have to do is buy a wireless switch and grab a computer network cord and plug it into your 2wire modem. I would advise just turning your the 2wire's wireless off. If the new router isn't strong enough you can buy directional antenna's or larger antenna's which should help with the range issue.
Unfortunately you can't purchase an antenna that you can directly attach to the 2wire.
Make sure that the switch you buy has external antennas that you can change out. If not and the range isn't strong enough then it could cause more headaches down the road.
Apr 07, 2011 | 2wire (1000-400108-001) Router
Signal is not strong enough to connect laptop downstairs away from Linksys 2.4 ghz wireless router in my home network. I have ethernet downstairs, can I attach another wireless router, as well as my PC to...
Looking at the specs for that Linksys router, it is a "G" size router. Most "G" routers only have an average indoor range of 150 ft. and that also depends on what type of construction materials are in the home that could hinder that range and the signal. Another router attached would only degrade the signal even more, that is not recommended. A stronger ranged router would probably be a better solution, possibly an "N" or "N+". Hope that helps.
Jan 22, 2011 | Computers & Internet
What is the signal distance for this wifi product?
Well, I have no idea which router you are using, but most wireless routers will send a signal 300-400 feet. Walls, trees and other obstructions may decrease this range. There are amplifiers you can buy to send the signal further, but environmental conditions may prevent this from being an option.
Please let me know if you need any more info, as I am well versed in wireless.
Hope this helps!
Regards,
Joe
Jan 03, 2011 | Computers & Internet
How do i conet to all my game cosoles
You need to purchase some "Ethernet Cords", these come in different categories of quality, ranging in price. Because of your router I would recommend that you purchase Category 5E also known as Cat 5E.
Before you purchase this cable though, you want to measure out how long you need each cable, to ensure you purchase enough to get the job done, and as well as allowing slack in the cable for instance if you want to hide the cables in the ceiling to make it look nicer, allow about 5 ft more then you think it will need. You can purchase Category 5E cables online here.
Another possible solution for you to connect to all of your game consoles would be purchasing separate wireless adapters per device, but that method isn't as cost friendly. For instance, the wireless adapter for the Xbox 360 is $99.99 from Microsoft here.
If this did not solve your problem, please leave a comment and I'll get back to it as soon as I can =)
Aug 12, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
Having trouble with range on DIR-655
Try to play around with the wireless channel of your router and check which one is best for your wireless network.
Jun 09, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless router
hi frank its a new thing to have to go out and decide what router to purchase and install i use a linksys and have had good luck with the wireless connection quality . does his laptop have a wireless lan card installed most new laptops do have one but its worth a look to make shure it does. depending on how much you want to spend how far away does his laptop sit from location of router ? if not more than 10 ft go ahead and purchase a cheaper one 60.00 now if you want a better quality one go with the twin antenna linksys for about 130,00 and please make shure that he installs the security software that comes with the router and make a password and secure it for shure .i hope ive helped you decide on what router to purchase they all work fairley good .
as far as how they work they are all plug and play install the cd software first then follow instructions carefully and set up is 10 minutes away good luck by for now
Jul 03, 2008 | Linksys Wireless-G WRT54G Router
Laptop
If all you're looking for is wireless internet within your home, then you can simply buy a wireless router off the shelf from Best Buy. However, a wireless router will only provide a range of a couple hundred feet, perhaps a couple of hundred yards. Essentially, it only provides internet access at a single fixed location. I'm getting the impression you're looking for something more.
If you're looking to have internet access wherever you go, no matter how far from home, you're going to need a subscription to wireless internet from a cellular provider such as AT&T or Sprint. They sell both internet access as well as the cards used to connect to the network, so check out their websites to explore your options.
May 15, 2008 | HP Smart Buy - HP Compaq 8710w Mobile...
Broadband router range
If you have wireless N router. You should install wireless N adapter on your children's computers as well. That way, they are compatible with each other coz I guess your children's PC has wireless G adapters. You wont be able to utilize the N signal of the router if your using wireless adapters..
May 15, 2008 | Computers & Internet
Wanting to purchase a router
Ok, my friend if you don't have internet services whether you use router or modem you won't be able to connect...
You can buy a netgear, buffalo or speed touch router they are quite good...
Feb 19, 2008 | Digi ConnectPort (CP-WAN-A300) Router
What are the wireless specifications of the 802.11b Wireless Router (F5D6231-4)?
F5D6231-4 802.11b Wireless Cable/DSL Gateway Router Output Power +13dBm-20dBm (50mW) (max.) Range (ft/Meters) 11 Mbps 5.5 Mbps 2 Mbps 1 Mbps Outdoors 590 ft (180m) 980 ft (300m) 1475 ft (450m) 1800 ft (550m) Indoors 50 ft (15m) 125 ft (38m) 150 ft (46m) 300 ft (90m) Reciever Sensitivity -76 dBm -80 dBm -80 dBm -80 dBm
Feb 16, 2006 | Belkin Wireless Cable/DSL Gateway Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
271 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
