Question about Braun 8585 Electric Shaver
My 8585 braun shaver will not clean the lights flash but nothing
The cleaning station will not clean my shaver. The shaver is a little over 2 years old. can it be repaired and how much do you think it will cost?
I checked the power to the station it gets 14 dc volts. The lights flash when i push the clean button but, then there is a click and nothing happens.
  • Braun Master
  • 1,602 Answers
There are several companies that can do this for you. Cost varies from one company to another and also depending on what your definition os 'refurbished' is. Do you want a new shaver head? What about new batteries? Do you have any other problems that need fixed etc?
One company that can do a wide variety of these repairs is shaveroutlet.com
Posted on Jan 15, 2010
    Novelist:
  • 109 Answers
These cleaning station units can be found in good used condition on "that auction site." I recommend you buy one from there. Or you can get a new replacement at a website like shaveroutlet.com. Good luck!
Posted on Oct 22, 2009
My braun 8585 is five years old and i would like to have it serviced and referbished, please let me know the cost if this is possible?
Posted on Sep 19, 2009
Make my own cleaning solution for my braun shaver 8585.
It is just an alcohol solution with a very small amount of cleaning solution. A jewelry cleaner premixed would do it.
Nov 20, 2014 | Braun 8585 Electric Shaver
Braun series 7 cleaning station has red lights even after I replaced the cleaning solution
When the razor is not regularly cleaned in the cleaning station and the hygiene indicator goes low, the cleaning station may lose its ability to sense the fluid level. I almost sent the cleaning station in for repair (mine is out of warranty) but was able to clear the faulty condition by resetting the razor's cutter replacement (holding the small recessed reset button below "Braun" logo on the razor) and unplugging/replugging the station then attempting a cleaning until it performed one completely successful cleaning cycle. After that the fluid level showed full. I also heard that the drain hole in the "cup" where the razor sits can get clogged - not sure what happens then but you want to keep that clean.
Sep 15, 2013 | Braun 8585 Electric Shaver
Braun 8585 shaver, charges fine, cleaning cycle acting strange where it thinks the razor is clean, but it is not. When new it cleaned at some level every time put in the cleaning base. Now it very...
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Oct 09, 2010 | Braun 8585 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
The cleaning station for my 8995 goes through the motions of cleaning but the bristles are no longer flushed into the fluid reservoir as they used to - they remain inside the shaver and also in the...
You can make sure you have a nearly empty old cart in your shaver cleaner base, and then run some rubbing alchol into shaver or even some mixed with some soap to help break down the oils in the stubble crud. If you can put some also in a spray bottle and use it to clean with a little force, that will help some.
Nov 19, 2009 | Braun 8585 Electric Shaver
How to change batteries braun shaver ?
It is suppose to be rechargeable and have a 2 year waranty on it. send it bback and get a new one or just take it apart and use regular batteries.
Aug 29, 2009 | Braun 8585 Electric Shaver
Just bought braun 8585 electric shaver, return it to the store as nothing happens while charging. Got a new one and still not able to charge it, shouldn't the indicator turn red or green? nothing happens....
Did you insert a cartridge into the cleaning base? It needs that in order to work. Otherwise, try plugging the charger directly into the shaver. It should definitely charge the shaver, as long as the shaver is fine. Depending on the model, the charging indicator may be green or blue.
Jun 03, 2009 | Braun 8585 Electric Shaver
Need a new Clean and Charge Base
yes, you can find it online , also you can find it on ebay if you search for braun 8585 .
Nov 25, 2008 | Braun 8585 Electric Shaver
Braun 8585 charger cleaner - not cleaning
you can try cleaning it with alchol and see if that helps it to become unplugged and able to clean your shaver again. It may also be some contacts that is on base where it contacts the shaver. If it still does not work, you will need to replace it . Look on ebay for one to replace with.
Nov 10, 2008 | Braun 8585 Electric Shaver
Braun 8585 Electric Shaver Logo
1,478 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
