Question about GE Refrigerators
GE Profile - model PDS22 - constant clicking noise
I have a GE Profile Fridge - Model PDS22MFSAWW - 2 Problems with it. 1. Constant clicking from the back - like the unit is turning off and on every second. 2. Temp controls don't change anything - digital display goes blank after setting them
Yeah, same problem. There are two capacitors that seem to be prone to going out. You can replace the main board, or (if you can solder) replace the two capacitors with slightly larger ones (radio shack mdl number 272-1030 works) just remember to bend them away from the heat sink if you go that route.
Posted on Jul 11, 2009
  • Jeanne Wong Nov 08, 2011
    I have the same problems. I just called GE, and they said that my model pds22mfsaww does not have a main control board. Is a main control board the same as the 'motherboard'?
I have a GE refrigerator model PDS22 and it doe not keep is temperature
Posted on Jul 24, 2009
I had the same problem. The "motherboard" in the rear of the fridge was bad. I could see a resistor was burned on it. I replaced the board (found it online) and the problem was fixed.
Posted on Jul 02, 2009
My ge profile arctica pss25sgna too cold
The air damper in the refrigerator section is stuck open allowing a constant flow of cold air into the refrigerator from the freezer section and it will need to be replaced. Here is the part to order.
Here is a diagram of that model. The damper is number 459.
Feb 06, 2013 | Refrigerators
GE Profile - model PDS20SBSALSS - constant clicking noise
The clicking is the compressor trying to start. If the compressor is extremely hot, try allowing it to cool. The condenser fan should run even if the compressor is out on overload; that may be the cause of the compressor failure. Check the supply to the fan and replace it if it doesn't run.If the compressor has been overheating for some time, it may be damaged and also need replacing.
Jun 13, 2012 | GE Refrigerators
My dishwasher has no power and am hearing A constant highpitched noise
i do have the same problem with my ge dishwasher(model PDW9280J00SS). i just replace the key pad now it's working ok. i got the key pad on line for about $70. part no. WD34X10915
Jul 09, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
Constant clicking noise with no cold air.
You have a bad main control board . This is located behind the refrig , behind an 8" X 10 " panel . Either the compressor module , or fan module , is burnt out . Replace this electronic board , and I'm sure the problem will be solved .
Sep 29, 2009 | GE Profile¿ Arctica® Energy...
My GE Fridge is making a clicking noise and Digital display out
Replace the mother board. (part # WR55X10942 )
Aug 21, 2009 | Refrigerators
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Stainless Steel side by side freezer noise
sputering and gurgling is a common complaint with lots of models. it is the surculation of the refrigerant thew the evapurator tubing behind the rear wall. make shure the units condensor underneathe the fridge is clean and clear of dust. it can cause the head preasure from the compressor to increase witch can cause excesive sound in circulation. hope this helps you
Oct 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ge fridge model gds20sbsss constant clicking sound
It the clicking sound is constant it's a bad mother board. Located on back of fridge under a cover panel. IMPORTANT TO READ INSTRUCTIONS YOU MAY HAVE TO CUT A WIRE ON THE WIRING HARNESS. This is dictated by SERIAL NUMBER OF REFRIGERATOR
Jul 05, 2008 | Refrigerators
I have a ge profile gas range and the burners are making a constant clicking noise and spark. The only way to stop it is by either unplugging it or turning the power off to it
Under each gas control is a switch that will turn on the spark module when rotated to the light position. One or more of these switches has failed. Some models these switches are individually replaceable, others the switch is an assembly of all four.
Jun 15, 2008 | Whirlpool SF368WWH Gas Kitchen Range
Refrigerators Logo
918 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
