TV will not come on or any sound. The connections are on tight.
SOURCE: Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a
technician, as several IC and components must be tested and eventually
replaced.
SOURCE: sony kp-51ws510 tv blinking light 6 flashes on timer/standby
6 blinks on your model means the +5V line is either overloaded or shorted on the A or B board. You can get replacement boards at the following link and they will assist you in determining which board of the two you actually may need.
http://servicemanuals.vstore.ca/
SOURCE: The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
you must change ic reg.(ic mcz 3001db)
SOURCE: sony rear projection tv KP-51ws510 red LED blink 8
High voltage problem, better left to a pro, expect to pay around $300-350 Julio [email protected]
