Question about Troy Garden
Need help with belt on Troybilt self propelled push mower
I'm having a problem with the belt on a troybilt self propelled push mower. The belt slipped off and I can't sretch it enough to fit around the engine pulley and the transmission pulley. I loosened screw that the manual said was the tension but that didn't do the trick. It's the same belt so it can't be the wrong size. Please help...I need to mow my lawn!
  • 1,040 Answers
Try removing the pulley in order to put the belt back on.
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker Jun 04, 2009
    Di removing the pulley help?
    Jim
How do you replace a drive cable on a troy bilt push mower model 12av834q711
I am assuming you want to replace the drive cable on this mover.
You can view this in detail in this video
https://www.youtube.com/watch?v=PbwO2ygfS0k
If you need the manual you can download from this site
Manual Troybilt Rotary mower 12AV834Q711
If not then please send a comment clarifying which cable you are referring to.
Parts can be purchased from this site
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Walk-behind-lawn-mower-Parts/Model-12AV834Q711/1307/1500600/P0601106/00002
Aug 12, 2014 | Troy Bilt 5.5hp Self Propelled Mower
What would cause a troybilt self propelled mower 12a-466m011front wheels to lock up when pulling back? Also why would this continue when mower is off?
There could be several things. Have you recently changed the belt? Was it an OEM belt? i have seen loose trannys cock in such a way as to put the belt in a bind and not let it slip when reversing. More likely is that there are dogs on the wheels and one or both aren\'t releasing.
May 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troybilt self propelled mower front wheels lock up when pulling back
most have small leaf springs that let it toggle back and forward, if they brake can cause this problem. Then it may just need the wheels removed, clean the parts and lubed
Husband says thinks it is starter cable has stretched and needs new one...does this sound correct and how to install it on Troybilt self-propelled push mower?
I'd love to help you, but I think you need to rephrase your question. There is no "Starter Cable" on this mower. Sorry.
James
May 22, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I need a owners manuel for a troybilt lawn mower
For Troy-Built USA, use this link and submit your model number and serial number to find and download your manual:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
For Troy-Built Canada, use this link and submit your model and serial number to find and download your manual:
http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
All other countries use this page and find the applicable website or email address then go to the applicable website or email the contact point:
http://www.troybilt.ca/troybilt/contact-world.asp
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a troybilt xp, and the self propel fontion
Does the drive shaft going to the wheels turn at all?
If it doesnt you may have a unsecured pulley on the engine.
If the shaft does turn when you engage the tranny your next stop is taking the wheels off and checking the wheel clutches. Sometimes called sprag clutches. They are probably both stuck in the unlocked position. You need to clean them up by removing all the greasy material covering them and putting them back together with just a few drops of light oil.
I hope this helps. Good luck and be careful!
Jul 28, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My self propelled high wheel mower doesn't go
If this is a TroyBilt 34068, check your belt to make sure it is still on the transmission pulley. If the belt is in place, start it up, engage the transmission and observe both axle ends where they protrude from the center of the wheels, if one of them is turning, you have somehow lost the square key that locks the wheel to the axle. Replace the key and you will be good to go
Sep 15, 2009 | Garden
Troy Bilt 33'' Replaced the self propel v belt and now the mower will not disengage from drive mode, also very hard to shift gears
If you didn't by the Troybilt belt, try that. I had the same problem with a Napa belt. Going into drive as soon as I grabbed the operator presence button, not coming out of gear etc. When I switched the the Troybilt belt, the problem went away.
Jul 17, 2009 | Troy Garden
Troybilt 6.5 wont start without some help
Check to see of where the canles connect to the linkage, there are usually thumb nuts you can adjust similiar to that of the brakes on a bicycle handle bar.
May 30, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
249 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
