Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Have a paper jam message
Hp Photosmart C4180 have a paepr jam message, no paper anywhere in the printer, so I hit OK and nothing happens. Printer is stuck.
  • 3,741 Answers
Ok.try this.
1)remove the cartridges from the printer.
2)unplug the wire at the back of the printer.there will be two wires one is power wire and other is usb wire.remove both from the back of printer.
3)then remove the other end of usb wire from the back of pc.
4)then wait for few minutes.say 5 minute.
6)then connect the power wire to the printer at its back.
7)then clean the brown colout dotted circuit of both printer and cartridge.with the help of dry tissue paper.
8)clean all the ink in the lower side of the cartridge circuit with a dry tissue.
9)then insert the cartridge and check out.
10)now without connecting the usb wire to the back of printer.check out that does any error light blinking on the printer or not.if not
11)then connect the usb wire to the printer and check out by printing a page.
12)but if any error light is bliking on the printer before connecting usb wire.then
13)in the back of the printer there is access door.to remove any paper jam if there is a jam.just check out by removing the access door.
this will help.
if still the same problem then its the sensor problem in the printer.there is sensor in the printer which detects the paper in the printer.if the sensor is broken then it will not detect paper and so it shows this error as paper jam.in this case the printer has to be taken to repair center to get the sensor replaced.
the cost of new sensor is $5 and local printer repair technician will get it done.
please do rate the solution.thanks you for using fixya.keep updated.thanks.
Posted on May 29, 2009
I keep getting paper jam messages when there is no paper jam.
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 23, 2009 | HP Photosmart C4180 All-In-One InkJet...
PAPER JAM WITH NO PAPER
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
May 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
Printer Cartridges won't align C4180 printer
Printer keeps trying to perform an alignment after installing a new black ink cartridge fix:
1. Unplug USB
2. Turn printer off
3. Wait 10 seconds
4. Remove paper from paper tray so printer has no paper to print on
5. Turn printer on
6. Printer messages to insert paper in paper tray
7. Press and hold “Setup” and “ Cancel” buttons and press “OK”
8. Should be good until next black ink cartridge change.
Nov 28, 2008 | HP PhotoSmart C4180 All-in-One Color...
Hp officejet all-in-one 6210
printer jerking and message says carriage jam and everything is clear, but paper goes in sideways.
Oct 13, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Paper Jam
My printer have an option to clean printer head.. If you too have the option please try it and see..
Sep 07, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
