Question about Sharp Viewcam VL-NZ50U Mini DV Digital Camcorder
VL NZ50U I get an a continuous eject cassette error message even when new cassette inserted and cam does not operate
  • noone_anil Dec 06, 2007
    I do have the same problem, please advise how to fix the problem.
  • Anonymous Feb 11, 2008
    same problem here as well
Hello i have a probleme like you with my VL DP3S
First you must cleaner the head with a cassette cleaner 5 sec max. if it's not ok you must consulting a specialist
Posted on Dec 22, 2008
My sharp vl-h860u keeps ejecting cassettes
Do you mean it is giving birth to a continuous stream of them, or merely that each tape you insert is rejected ?
Dec 08, 2013 | Video Cameras
Sharp video camera VL-AH50
Did you try cleaning the tape head?
Feb 22, 2008 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Canon ZR500 won't close cassette bay
If your camcorder experiences an error, you may be presented with a ?Remove the Cassette? message. There are several reasons that this message may appear, but it is essentially a safety warning that is designed to protect the camcorder and/or tape from damage. The camcorder?s tape drive mechanism is made up of many precision components that, once damaged, may cause further problems if the mechanism continues to operate. When a problem is detected the safety mechanism is activated. The ?Remove the Cassette? warning and the camcorder?s safety mode may be activated by a variety of conditions such as: 1. Condensation is detected ? If condensation is detected by the camcorder, the ?Remove the Cassette? warning may occur. 2. Component failure ? If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder. 3. Sand or grit damage ? The camcorder?s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate. 4. Impact damage ? If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur. 5. Liquid damage ? If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation. 6. Improper videotape insertion ? If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual. 7. Damaged or defective tape ? If a tape becomes damaged, please discontinue its use. Operational Recovery Steps Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps: 1. Eject the videotape Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2. 2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry. If the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST). Alternatively, if electronic support is preferred, please send your email to
Aug 27, 2007 | Canon ZR500 Mini DV Digital Camcorder
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
I have a Sharp ViewcamZ VL-Z900. DEW error
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Sep 18, 2009 | Cameras
Computer not reading my cam
u need to first install your software that came with your camera and then plugin your camera after restarting pc
Jun 25, 2009 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Sharp Viewcam VL-AH151U keeps saying "eject cassette" why is that? How or where can i send this to get fixed?
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Jan 18, 2009 | Sharp Viewcam VL-AH151U Camcorder
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
Sharp vl-nz50
i need the software and the driver for my video camera
Nov 25, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Sharp Viewcam VL-NZ50U Mini DV Digital Camcorder Logo
257 people viewed this question
Top Sharp Video Cameras Experts
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
