How to unlock the dvd player to region free
Well, you may take a look at Leawo Blu-ray Player, which is totally free and allows you to play back all Blu-ray/DVD discs from different places and countries: https://bit.ly/2zTzeoW
If you want to make your players region free, you can go to VideoHelp forum and then go to the DVD hack section. All you need to do is to type in a model of your DVD player and then search for the hack exclusively for your model. If you are lucky enough, you will find a very detailed instruction to unlock the region code for your player. Just follow the instructions and you should be able to make it within a couple of minutes.
You can also use some tools to remove region code such as Leawo Blu-ray Copy
Once a DVD player has been assigned a region, it cannot be undone. You can change regions (generally 5 times) before it locks on the current region, but to have a region-free DVD player again, you need to buy a new device.
NO country stated,?
no region stated at all be that where live
nor the DVD disks in hand,
but here is your answer. 1997 to now endless drives covered.
Importing region free dvd drive in usa is *******. what you do is your call.
https://www.videohelp.com/dvdhacks
some DVD drives can change region 3 times max
some DVD we have firmware hacks read above link.
some DVD can not be changed.at all, non told by you.
there is only one answer here lacking zero facts from OP. read the linked website.
read or omg post there.
see that tag, only this matters. first.
all you do is see if your unstated drive can do this or replace it.
some can , some can not same allow 3 to 5 changes then locks down.
NO DVD drive top label data presented no real help.
the answer for decades is here.
first off no 2 player models are the same unless are exactly, so there is no ONE ANSWER,.
no country stated, so what is legal, is not known.
learn to read here, or omg post.
