I need to know the wattage/power or current used.
What is the wattage/power/current used by the amana turbo 210 washing machine?
  • 332 Answers
UNLESS IT'S COMMERCIAL IT SHOULD BE 115
Posted on May 29, 2009
Amana YNED7200TW & NFW7200TW
then you are out of luck unless you know someone that can build you one
Jul 04, 2016 | Amana Washing Machines
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
How do I bypass the door lock on a front load Amana washing machine?
it should be a celenoid lock, possibly if you disconnect the power it will unlock, if not I don't know.
Jul 12, 2015 | Amana Washing Machines
No picture with GeForce 210 graphics card
Picture? Are you saying it does not work? Is this a new install? Is it setup/installed correctly? Have you installed the software? Drivers? Need more info.
Mar 20, 2013 | HP Pavilion a1423w PC Desktop
I want to find out how many watts does the kenmore 400 series uses
Maybe a dumb question, but what do you need a transformer for a washing machine? Washers typically plug into a standard 120 volt 15 amp outlet. To figure out the wattage, use the simple formula, P=E x I. There will be a tag somewhere on the machine stating current draw, which is "I", "E" is your voltage, and "P" is your wattage which is what you'll figure out after reading the label on the machine.
Jul 23, 2012 | Kenmore Washing Machines
Given 1hp motor how to compute the exact amount of amphere use in circuit breaker
You're not going to be able to do this with just a known Horse Power.
There are 3 elements to the equation, with any two, you can work out the third.
If you want to know how the amperage, you will need to know the voltage and wattage of the motor. I imagine that you already know the voltage (It's going to be 220V or 110 volt)
Watts divided by volts = Amps
Examples:
A 220v 1000 watt motor (1000 divided by 220) will draw 4.55 amps
A 110v 800 watt motor (800 divided by 110) will draw 7.27 amps
Bear in mind that most washing machines have a couple of windings for wash and spin. As an average, the was winding will usually be about 500 watts to spin and about 250 watts to wash. ALSO, bear in mind that if you are using this data for a WASHING MACHINE, then there is a water heating element in there too and that draws about 2Kw (2000 watts)
Dont just take this as read, you DO need to check wattages, but, working on what I have just said, the max consumption on a 220V machine will look like this:
At Spin, with a 500 Watt consumption: (500/220) = 2.3 amps
While Washing with a 250 watt consumption: (250/220) = 1.14 amps
Consider that the WASH and HEAT may be running at the same time.
2Kw heating (2000/220) = 9.1 amps PLUS 1.14 amps for the motor - Total wattage 10.24 amps
Watts / Volts = Amps
Amps x Volts = Watts
Watts divided by amps = Volts
Aug 25, 2011 | Washing Machines
I bought an xps 210 2 years ago. The power supply is dead
It is possible that you picked up a faulty power supply, slim, but possible. Chances are pretty good that you have one of your components drawing too much current on your power supply. The largest power drain comes from your processor and the graphics accelerator cards, however it could be a faulted motherboard or hard drive. You can replace your power supply with a larger capacity unit from a known good manufacturer. If you increase the wattage capability and look with the side off to see if any component is generating a lot more heat than usual. A larger capacity power supply should be able to handle the unusual current draw.
Apr 18, 2010 | Dell XPS 210 PC Desktop
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
What is wattage of kenmore 110.22942101
Now you have presented and interesting question. Lets assume your washer uses 120 volts and during different parts of the cycle it uses more watts. Here is a link to a calculator. Just remember the higher the voltage the lower the watts. Sea Breeze
http://www.crownaudio.com/apps_htm/designtools/ohms-law.htm
Jun 28, 2009 | Kenmore Washing Machines
Maximum power draw
Should have a name plate that lists the wattage or amperage.
Typically Dryers have 4000 to 5000 watt elements and have to be fused at 30 Amp. (Or breaker must be 30A)
Motor is much less current or wattage. The element uses the lion's share of power.
I looked for a manual but LG doesn't have one available.
Nov 18, 2008 | LG DLE2514 Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
