Question about Digi 002 Rack FireWire-based Pro Tools LE External Sound System
Firewire ports not responding to computer(s). "Unable to locate hardware"
Firewire ports not responding to computer.
How do i install sound drivers and power dvd to my laptop?
Posted on Jun 01, 2009
Hi i have digi design rack 002 with pro tools le
Try the other port on the 002. If that doesnt work, I recommend trying the 002 on a computer that does have 400 to see if it will connect then.
If it doesnt, then you may have a couple blown firewire chips inside your 002. It happens, and can be fixed.
Jun 29, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
Tip
How to connect an iPod to a computer connection
<p>The iPod is one of the world's most popular MP3 players because of its ease of use. You can simply drag and drop video and audio files from your computer to the device to your collection on-the-go media to expand. The process of establishing this connection with your computer is easy, and maker of the iPod, Apple only requires that the freedom of the media management program, iTunes downloads to begin adding audio and video on your iPod. <br /> <p><br /> <p>1. Identify your hardware. If you use a computer with a USB 2.0 port, then you have it easier because all you have to do is plug in your hardware. If you are using an older computer (usually with an operating system to Windows 2000), then you have a USB 2.0 port, in which case you should consider using a FireWire or USB 1.1. If you do not have FireWire or USB 1.1, you need a card or adapter. <br /> <p><br /> <p>2. Identify your iPod. Fifth-generation iPods or later can be connected using standard FireWire adapter cable option, but otherwise requires USB 2.0 ports. You can also use standard iPod USB 1.1 ports, but it requires an adapter. The Nano and Shuffle models can only connect via USB ports. <br /> <p><br /> <p>3. Connect the iPod cable that you use on your iPod. The larger end of the cable should fit in the bottom of your iPod, whether it is a standard FireWire cable or dock to the USB 2.0 connection. <br /> <p><br /> <p>4. Connect the other end of the cable to the designated location. For USB users, this will be a USB port on your computer. If you use FireWire, and connect it to four or six-pin FireWire is not. <br /> <p><br /> <p>5. Download and install iTunes if you do not have the software. It is a free program your iPod. If you had installed before establishing the connection, it will open and audio / visual files or on their own. After transferring to your iPod files to load or eject. <br />
on Aug 09, 2011 | Apple iPod touch
Unable to locate hardware is what my mac says..... Power on
unable to locate hardware is what my mac says.all lights are on
May 14, 2010 | Digidesign Digi 002 Rack FireWire Pro...
Im unable to capture video through my firewire
Please reinstall Camera driver and tri agene.
If it’s not working than check your system hardware capability.
Thanks & Regard
Abhay Singh
Oct 12, 2009 | Computers & Internet
Unable to connect Sony DCR-PC3 handy cam to my pc
make sure that you are using the correct firewire plugs (4 pin on the camera and 4 or 6 pin on the computer depending on the computer). If you are sure you have all this correct, check your BIOS settings for a disabled media card or 1394 controller.
Apr 10, 2009 | Sony Handycam DCR-PC3 Mini DV Digital...
002 digidesign console
i think you blown your fire wire port,try something else in those ports and see if they work..
Feb 26, 2008 | Apple Power Mac G5 Desktop
Firewire connection not responding
Take a magnifying glass to the firewire port on the camera. Check to see if it looks damaged at all. I've used firewire with my students for many years and this has happened to me on more than one occasion. The student is not as careful as he could be when plugging in the cable. The inside of the firewire cable becomes damaged. This is a cheap fix. Buy a new cable. However, when the port is damaged, it is an expensive fix. Since the computer recognizes another camcorder it may not be the computer. And if you are using the same cable, then it will probably be a hardware issue with the camera. Look at the port and let me know if anything looks out if place.
Jun 29, 2007 | Panasonic PV-GS65 Mini DV Digital...
JVC GR-D275 not seen as connected to computer
Many Camcorder users have faced problems while connecting their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder. This can mean two things. Either the DV port on the Camcorder is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault. Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
Dec 21, 2005 | JVC GR-D275 Mini DV Digital Camcorder
Digi 002 Rack FireWire-based Pro Tools LE External Sound System Logo
778 people viewed this question
Top Digi Computers & Internet Experts
Matthew Spark
Matthew Spark
doggzzz
Level 1 Expert
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
