Question about Kenmore 17252 Free-standing Dishwasher
It will not begin to fill
It is plugged in and the water is on as usual, and I pushed the start button. It did not start filling right away, nothing but silence.
  • 332 Answers
MAKE SURE THERE IS NOTHING BLOCKING THE SWITH ON THE DOOR, IT WON'T COME ON TILL THE DOOR IS CLOSED AND THERE SHOULD BE A LITTLE PIN ON THE DOOR THAT OPERATES THE SWITCH, IT PUSHES IT IN TO LET IT KNOW THE DOOR IS SHUT
Posted on May 29, 2009
Model SM8280867. Why does it fill, then spin without washing?
1.try to unplug your unit then wait for 5 minutes
2.plug back your unit
3.program back your unit and start
Sep 05, 2015 | Whirlpool Washing Machines
Why does drain motor start when pushing the start button on the door before the door is closed?
It's almost certainly the float switch in the bottom of the machine. In the bottom is a polystyrene 'float' that is either active due to water in the bottom or is faulty. Tip your machine to the side and remove water and try again, bridge or replace switch is also an option
Jul 07, 2013 | Bosch Dishwashers
I obtained Bunn CWTF15-APS from a restaurant next door to my office. They were no longer using it and had left it outside over the winter. When I hooked it up there was water leaking as a result of a few...
Have you tried running vinigar or a cleaner throught with the water or running a wire up it .Sometimes they plug up withlime and will not allow the water to run.Be sure and rinse it well after the cleanser so everything runs clear and you may have to do this two or three times, depending on how pluged it is.
Oct 16, 2010 | Bunn CWT 15-APS Coffee Maker
The washer starts to fill normally, then agitates very briefly, stops, and begins to fill again. When watching the water fill, the water level does not rise at all, and if you push the button in to stop...
It sounds like your drain hose is two low. If your drain hose is inserted into a drain pipe try extending the drain pipe to the same hight as the washing machine.
Dec 27, 2009 | Washing Machines
LSQ9010PW6 fills with water, doesn't agitate right away
hi there......i think you've stated the problem....somewher you got a loose wire or plug....with apliance switched off..check motor plug first and then work your way back to wall plug......
regards Sir Galahad
Aug 21, 2009 | Washing Machines
My dishwasher seems to start ok then the first light starts flashing and it do'es nothing just stays there any ideads what my problem is
Can you tell if it's filling with water. The first thing it does is fill with water (usually on a timed cycle) before the pump starts. If there's no water in the tub, it obviously won't wash dishes, since a dishwasher is nothing more than an enclosed pressure washer. If it does not fill with water, you may have a bad fill valve or the timer that turns the fill valve on may be defective. You DO have the water turned on, RIGHT?
Jun 11, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Push start button fills with 2in of water then does nothing
hi there........this fault is usually associated with a faulty flow meter....situated on the lower left hand side of the apliance and is only accessible on removal of the left hand cabinet panel
regards Sir Galahad
Apr 15, 2009 | Beko 24 in. D3421F Free-standing...
Machine will not work and flashes 12 minutes
remove bottom cover look for tech sheet usually on right side of cabinet at bottom fh is usually a water fill issue drain may be siphoning water may be slow filling or bad flow meter flow meter may be harder to diagnois but try tapping lightly with screwdriver (it's the round object left side with 2 small hoses attached ) slim chance may be pressure switch left side rear corner
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Sep 01, 2008 | Washing Machines
    Kenmore 17252 Free-standing Dishwasher Logo
    117 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
