I need to remove cover of compaq presario sr2104fr to install more memory. How do I remove the cover? Thanks.
  • 749 Answers
Remove the two phillips head screws holding the side panel , they are located on the back of the computer. after removing the screws, the side panel slides back , then lifts off.
make sure you unplug the computer and touch something metal to discharge any static electricity you might be carrying, before you install the memory.
Posted on May 29, 2009
  • 489 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=fi&cc=fi&lang=fi&product=3369542&docname=bph03886
this is all you need. pls rate this.
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Compaq Presario CQ50-215NR The computer has a beeping sound like a car alarm. while to Operrating system is running. It wont stop beeping
Hello.
The most common reason for this problem is memory. They could be slightly loose or faulty.
Disconnect all cables. Flip over the laptop and unlock and remove the battery.
Remove the memory cover. Remove and reinsert (on a slant) the memory module(s). Replace cover and battery.
Power on again.
If the problem persists, a memory module could be faulty. Follow the above instructions but test one module at a time.
Hope this helps.
Nov 08, 2011 | Compaq Presario CQ50-215NR Notebook
Won't start and getting long beeps. compaq presario 6370
The beeps that you are hearing might indicate that your computer has a bad RAM or memory modules already. Reseating the memory modules might resolve the problem. That means you have to remove then place back the RAM. The full instructions in installing memory modules can be viewed from this LINK and should give you an idea how to remove and place them back. If the problem persists, replace RAM/memory module.
I hope this works for you. Kindly comment for further assistance. Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 14, 2011 | Compaq Presario 6370US (OBDA219A#ABA_1) PC...
I own a Compaq Presario S5000V Desktop. I removed
Hi!
What you need is a pc2100 266Mhz memory card..where o buy this?
Just click the link to order from their sites.
http://www.memory-up.com/Memory/CompaqPresarioS500013970.html
Much appreciated if you rate this help..thanks!
May 25, 2010 | Compaq Computers & Internet
Want to replace 2x 256mb of memory with 2x 512mb of memory into my hp compaq presario v4000
Hi there.
Yes you can upgrade the memory to 2 x 512MB DDR SDRAM memory.
You will be pleased to know that the system supports up to 2GB DDR SDRAM memory (2 x 1GB)
Please be gentle when installing the new memory taking care to remove the battery and the mains power from the laptop first before installing.
Have fun and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq Presario v4000 Notebook
My Compaq Presario M2000 will not power up.
hi im josh in cebu phils.may i help you? Friend if that happens that it will not turn on after doing such things I suggest to remove first your DVD burner and installed back your Memory.be sure it is seated firmly in its position try to see the marking on your memory and on your mainboard.then try to reboot your pc. after rebooting if it powers on so thats the time you go back again in putting back your DVD burner. Remember dont install your DVD burner unless your pc turns on to avoid misleading. try to do it bro. good luck hope i helped you.
Feb 26, 2009 | Compaq Presario M2000 Notebook
Install memory
Use the following steps to remove a memory or continuity module:
Turn off the computer.
Windows 98 or 2000: Click Start , Shut Down , and then Shut Down
Windows XP: Start and then Turn Off .
Unplug the AC adapter, if present, and remove the battery.
From the bottom of the computer, remove the screw holding the RAM cover, and remove the cover.
Remove the board by pulling it away from the connector at a
45-degree angle.
Align the keyed (notched) edge of the board with the keyed area in the expansion slot. Insert the board into the slot at a 45-degree angle until it is seated.
Push the front edge of the board down until the retention clips snap into place. Then replace the cover
Aug 25, 2008 | Compaq Presario Notebook
Front cover
Ca you please tell me what type of PC you have? Compaq, HP, Dell?
Thanks
Jack
Jun 13, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Memory
I FOUND A SITE TO GIVE STEP BY STEP INTRUCTIONS TO PRINT ..YOUR INFO WAS VERY HELPFUL THANKS ALOT
Apr 04, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Dec 12, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
