Question about Dell Dimension E520 PC Desktop
I cant git sound
The graphics card fan turns on and powers up when i plug it into my Dell Dimension E520 but no matter what i do there is always a black screen with my moniter, theres no problem with my screen or my PSU. A reply would be highly appreciated I have no sound
  • Dawn
    Dawn May 11, 2010
    have you installed memory lately...or unseated it and reinstalled?? Often, a video problem is due to the memory. Carefully, remove your memory, reinstall making sure it is all the way in its slot and locked. Make sure you unplug your main power and turn off monitor before you remove the memory. When it is back in and tight.......plug the main power cord back in.....then turn on your monitor and restart your puter..... Do you get any beeps when you boot up??? Hope this helps
  • Jubert Ledesma
    Jubert Ledesma May 11, 2010
    Were you able to see the Dell Logo on restart? If you did not see any dell logo on restart do you get any beeps? If you do not hear any beeping sound check the color of the light both on the monitor and the tower... what color are they? Do you see any diagnostic lights on your system. Which lights are on? Have you tried a different cable?
  • 916 Answers
If your monitor is fine try changing the data cable to one you know to be working. If it still does not work then the graphics card needs to be replaced.
Posted on May 30, 2009
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
I have a Dell Dimension E520 that I've used for
If the power LED is solid Amber, then the like answer is a bad motherboard or peripheral connected to it. So, remove any expansion cards (I See you already removed the Graphics card) and all external connections (Just use power cord) and see if the system will power on with any different indications. If the power LED stays Solid Amber, replace the motherboard
Aug 07, 2011 | Dell Computers & Internet
I installed a ASUS GeForce GT430 (ENGT430) about a month ago and it worked great. Now when I turn my desktop on, it never posts but just sounds a bunch of long buzzes. If I remove the 430 card and plug...
The graphic card could most likely be dead. If when you turn on the computer, you hear a series of beeps, either long or short, it could be a boot error code. Writting down the sequence could give further explanation of the error.
Jul 19, 2011 | ASUS ENGT430/DI/1GD3(LP) GeForce GT 430...
I turned off the Dell Dimension e520 before a storm. I have tried numerous times to turn it back on, only to have a yellow flashing light. How can I get my computer to turn on?
Good day.
Here's my point of view of you problem. I have also experienced the same problem since it is always raining here in the Philippines. I just have to ask a few questions before i can give a direct solution to you.
Please provide the following:
1. Do you have a voltage regulator in your computer set. 2. Do you hear a beeping sound everytime you turn your computer on after the incident happened? 3. Does the processor fan still runs after turning your PC on or not? 4. Kindly provide your computer specs.
Good day and should you have any questions regarding the questions, feel free to approach us.
Jun 15, 2010 | Dell Dimension E520 PC Desktop
I added a 4 port usb card to a dell e520. The
try updating the drivers to the card to see what happens. another solution is try it on another computer. if the same problem exists on another computer you could have a bad card.
Mar 30, 2010 | Dell Dimension E520 PC Desktop
No power on dell e520 dimension
On the 20 pin connector, short the green wire to any black wire with a paperclip. This will force the power supply to turn on manually if the motherboard is not giving the correct "ON" signal.
Feb 26, 2010 | Dell Dimension E520 PC Desktop
Dell E173FP stuck in power save mode
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
May 09, 2009 | Dell Dimension E520 PC Desktop
Blank screen
Hey I am also facing same problem.But My card was woorking fie before yesterday.
I bought a new CPU cabinet> so had to remove nad reinsert the GFX card and it giving me the same problem as you are facing....
i.e. the fan is moving but screen is blank
Help plz.
Apr 18, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
Dell Dimension E520 PC Desktop Logo
97 people viewed this question
Alun Cox
