Question about LG 42PC3D 42 in. Plasma Television
LG Plasma 2 years old just started turning off and on
The tv goes on and off sometimes a few times in a row and sometimes it takes a little longer. Any suggestions - we checked with our cable company and they checked out connections and gave us a new cable box. Assume it is the TV. Any suggestions. My TV tries to turn on, but it just shuts off. I tries again and again. the only way i can get it to turn on is by turning it off and on using the power strip. this started after our power company had a black out a few months ago. Is there a part that can be changed to correct this?
  • 187 Answers
You will need to replace the mainboard, you only need to be sure your cable box is connected to the TV using ONLY one cable because if you use HDMI and another cable (ie. HDMI and COMPONENT) could show that sympton.
First try unpluggin everything from the TV and try to turn it on, if you continue with the trouble then you can be sure you need to replace the mainboard.
Posted on May 29, 2009
I have an LG 60PV400 plasma TV. While watching TV the screen goes black but the sound keeps playing. Sometimes the sound will just keep playing. Sometimes the TV while shut off.
Hi Joseph
Not sure what the LED codes will be. LG Tech support would know.
Is it under warranty still? If so, then get it to a service centre.
If not, Then you might want to check for leaky Electrolitic Capacitors.
This is the biggest ploblem with modern Digital (computer) Flat Panel TV's
Might be a little early to spot the "Bulging" or leaking until it gets worse.
If your up to it & you can spot the bad caps & unsolder & replace for a few bucks.
Good Luck
Switched mode power supply
How to Replace an Electrolytic Capacitor
Take Static Discharge Precautions inside devices
Antistatic wrist strap
Feb 13, 2016 | LG Televison & Video
My lg plasma really flickers but it does this randomly. Sometimes it will happen all the time other days not at all. I have tried sorting the cables and unplugged etc. it is 10 years old but just wanted...
I suspect its a component (Capacitor) aging and eventually would need to be replaced. How do you have it connected? Is there a cable box or Direct TV receiver that you use to display TV Channels? If 10 years old does it even have an HDMI input? Should be very happy you got 10 years of life out of this Plasma. My thoughts is that it would take more to repair this than to purchase a new LCD or LCD/LED thinner TV. Plasma does have the best color but the LCD and LED TV's are much lighter/take less energy and are much brighter. Good luck.
Dec 10, 2014 | LG 42PX4DR 42 in. Plasma TV
Vertical lines on LG 42 inch
check your LCD connectors. also video memory.
May 29, 2009 | LG 50PX1D 50 in. Plasma Television
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
LG 42PC3D Plasma TV Will Not Stay On
Could be a failing poser supply
Apr 22, 2017 | Televison & Video
LG 50" Plasma Start Up Problems
The logical fix would be to activate your 3 year warranty, messing about yourself is unlikely to fix it and very likely to void your warranty. The time for do it yourself repairs is when you have no warranty.
Nov 25, 2017 | LG 50PC5DC 50 in. Plasma HDTV
LG TV not turning on
Yes you can get this fixed and it is still worth it. It may cost $200 but it should last a long time.
Nov 12, 2008 | LG 42LC2D 42 in. LCD HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Samsung HD tv help
Is it a Plasma Television? I recently had a customer have the same issue with a 2 year old model Samsung 50" plasma TV. In his case one Of the computer panels failed. He didn't have a service plan and the warrenty was out, so i directed him to Samsungs help line. They inturn directed him to a authorized repair center. Repairs were roughly $800. Thats a possibility but it may not be the same as your issue. Try leaving your TV running for a little while when it has the issue, and see if it eventually goes away. Some older plasma models have started to require a warm up time for the pixel cells. This has been a down fall of plasma that for the most part no longer exists on newer models.
I hope eveything works out.
Have a great day
Mar 22, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
My plasma tv picture is green
take off back panel and adjust the V12(A) adjuster wheel on the power board it adjust the gas flow to the screen is should light up your screen
Sep 30, 2007 | LG MZ-42PZ14 42 in. Plasma Television
LG 42PC3D 42 in. Plasma Television Logo
146 people viewed this question
Computer Repairing
Computer Repairing
