Question about Dometic Rooftop RV Air Conditioner
Fan stops turning after about 30 seconds
My roof top A/C fan starts to run and blows cold but it stops after about 30 seconds and the compressor stays on there is a capacitior mounted on the motor itself how do i test it to see if its bad and causing the motor to over heat and shut down. Also if i leave it on the motor trys to run but in cycles and only for about 1 to 2 turns and stops again
  • 1,889 Answers
This sounds like one of your capacitors has failed
using an insulated screwdriver and, power not applied remove the spade connectors from one of the capacitors then short the capacitor to ground to discharge it replace the spade connectors apply power and, turn it on if the problem changes replace the capacitor (a bad capacitor usually is "bulged")
there are usually two capacitors a run and, a start
Posted on May 29, 2009
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
Was staying cold and then just stopped cooling. compressor sounds like it comes on but does not stay on feels like it is running and gets really hot have not found a fan
Try replacing the compressor relay (no more than $30) ,but if still doing the same ; the compressor has a start problem and you might have to replaced it.
Sep 28, 2009 | Freezers
Blows cold but shuts down no freeze up
Check the capacitor. It should be a dual capacitor , runs both compressor and fan. This sounds like your problem only because both the compressor and the fan go out together. Good Luck Hope I helped
Dave
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Have roof top air conditioner that blows air but soon trips breaker. any suggestions? Henry
check the condensor fan in the rooof unit. It's the fan blowing on the cpil on the roof.. If it failed, the head preasures can becme excessive andwork the compressor hard causing the breaker to trip. Let me know and good luck, Ned_
Sep 13, 2009 | Dometic Rooftop RV Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Both Fridge and Freezer not blowing cold air.
with the thermostat turned to its coldest setting can you hear or feel the compressor running?  Can you find the defrost timer inside the refrigerator and turn it until the compressor stops, and then please let me know, JT
Oct 24, 2007 | Amana AFD2535DES French Door Refrigerator
Dometic Rooftop RV Air Conditioner Logo
234 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
