Will not bootup
The pc wont start completly, just come on for a few sec then shuts down then on then down exc.the power supply tested ok.. put in another hd with an os and the same resault.. any idea would be grate. thx rb.
  • rb10594 May 29, 2009
    thankyou for your prompt peply. but no change with the drives unpluged. all i see is the e logo on screen then it turns off and on by it self. when the e logo stays up for a few i see boot menu f10 and bios menu f12 but they will not let me in. this is an emachines
    rb
  • 431 Answers
Hi I am Vortash try this s a test .. disconect all cd and Hd drives and any external connections including printer etc .
Turn the computer on and see if it does the same thing if it loads the fiirst part of the start up ie: the bios start up and says no opperating system or words to that effect the computer board and processor are probably ok . connect the drives one at a time and start up till the problem re occurs starting with the hard drive .. you may have to get into the bios and make sure the HD is showing and if not set the ide or sata on auto so the computer finds it .. press F10 save and exit then re-start .. if you still get no luck getback to me I will monitor your progress on here . Regards Voratsh
Posted on May 29, 2009
  • clive pearson
    clive pearson May 29, 2009
    Hi ok then from the sounds of it either one of three things have happened .. you have a power supply fault and it is possible you have lost one of your voltage rails or your cpu is corrupt or faulty or your bios has a fault either way I dont think your going to get much joy wtih a question on here this is a hands on job .
    It would be amazingly lucky if someone did drop on the fault as there are so many things at this stage it could be . This is not a software problem it's a hardware fault and that takes an engineer with a first hand view of the unit and able to do some detailed investigation Regards Vortash
  • clive pearson
    I have just thought of something else it could be .. faulty Ram if you have more than one slot of ram take one out and try startup if it don't work take the other out and replace it with the first one you removed .. as faulty ram can do this sort of thing ... Vortash
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
Dell e5420 wont start up at all
Make sure no accessories are plugged into your laptop. First remove the battery and try a bootup. If does not bootup, remove the hard drive if you can and try again. If still no full boot, you can try the DVD drive and then the memory. Replace what you have found to be the problem. If none solves the bootup problem, it is either the power supply itself or a mainboard problem, which would required service from an authorized service center from Dell. Verify the center with Dell. The parts I have indicated to try are normally easily removed from the bottom of the laptop, by removing a few small screws.
Mar 15, 2013 | Dell Latitude E5420 Laptop Computer
Temperature sensor
needs a new heatsink & fan fitted, also the old thermal paste will need removed from cpu and new paste put on. that should fix your problem
Jun 18, 2012 | Packard Bell iMedia Computers & Internet
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
Shutting down almost instantly when powered on, sometime runs for ever , then on a restart it just shuts down. anytime i hit restart it shuts down wont start up again unless i power it completely off...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
Nov 17, 2010 | Acer Aspire L100 PC Desktop
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
Bootup
a bad power supply or a hairline crack in the mobo
Jun 04, 2009 | ASUS (P4BGV-MX) Motherboard
Possible Fan Problem
You may have a power supply problem.
Might not be pwering enough to run the fan.
I would have my power supply tested.
Some places will do it on the spot for free
Jan 12, 2009 | Acer TravelMate 290 Notebook
Compaq Presario SR1030NX fails to start
Sounds like the power supply or motherboard is biting the dust. U may consider power off, open case and clean out the dirt, check U'r connections and if the power supply smells, replace it.
Else replace the pc. When the power supply dies, it usually stresses the motherboard out and it dies later, sooner.
Jun 02, 2008 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
