Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Installed a honeywell rth7500 series thermostate, no air
With the system set on cool, the fan on auto, and the cool on, the a/c will not come on. There is heat coming from the vents.
  • gator42_2001 May 11, 2010
    is this a heat pump tstat? if it is you will have to configurate it for heat or cooling o or b o is for cooling b is for heat,how do you have it wired?
    President:
  • 3,433 Answers
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
Posted on Jun 01, 2009
The honeywell thermostat I installed th8110r1008 system is in off also fan is in off but fan starts Up ?
There is no off selection for the fan. It likely has on or auto, but, it possibly has "circ." This will randomly bring the fan on with no call for heating or cooling. Keep your fan selector in the auto position, system to whatever you need!
Aug 07, 2017 | Honeywell Heating & Cooling
Honeywell TH6320WF when i turn system to heat and fan on auto it says heat on but never clicks on but then when i change fan to on the system clicks on but it seems to be blowing cool air
It sounds like the heat setting is not high enough. The heat setting needs to be higher than the indoor temperature or the fan will just blow non-heated air.
Dec 03, 2016 | Honeywell Heating & Cooling
Honeywell tstat not working in auto cool mode
so with system setting cool/ fan setting auto, the condenser runs but the indoor blower does Not? but when system setting cool /fan setting on, the condenser runs and the blower runs?
Oct 25, 2017 | Honeywell Electronic Programmable...
Honeywell th6000 thermostat installed. It shows only heat-or off- no cool. The fan doesn't show up as auto or on. Now air conditioner has turned on and it is -15
If you just installed the stat, you need to enter installers programing to set it up. To do thi, press and hold "UP" and "FAN" until a number on the left and right show up. The left number is the function and the right number is the setting. You do not specify what type of system you have, so i cannot tell you exactly what settings. But here is a link to the installers manual. the installers program settings is about half way down. http://www.forwardthinking.honeywell.com/related_links/thermostats/focuspro_6000/install/69_1920es.pdf
Feb 06, 2010 | Honeywell Programmable Thermostat Heater
System fan does not come on.
if the out door unit has been working carefully jump red to green the fan should come on if not problem is bad fan motor or capicitor or fan relay hope this helps
May 24, 2009 | Heating & Cooling
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
May 16, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Replace Carrier tstatccshp01 builders standard thermostat with Honeywell rth7500 series and wiring not matching Does O wire go to Aux..? fan working but no cool air.
No... Aux. is auxiliary heat strip. This is usually a white or black wire its up to the choice of the installers preferance. O or orange wire. is used to the reversing valve on a heat pump. If you do have a heat pump there is a programing section inside the Honeywell t-stat. which should say heat pump or straight cool, then another section that will ask if you want the reversing valve to energize in heat or cool. most Heat Pump brands energize in cool the exception is Rheem and Ruud they energize in heat.
May 17, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
402 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
