Cant find auto convergence in menu
My convergence is all out of whack and I cant seem to find which menu the auto convergece feature is in. please advise so I can see if it will fix it or if the convergence circuit is out. Thanks.
  • 8,617 Answers
Thats a common problem that is usualy corrected by replaceing FL231, DL231 and CP230 you can get the parts with instructions on how to do the repair at the following link. Cost about 11.00 shipping is free. The parts are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
Posted on May 29, 2009
TV NEEDS TO BE RELINED ;IDONT KNOW HOW/
The Auto convergence feature listed under the setup menu will do it automatically. A common problem is the auto convergence feature will disappear from the setup menu. If yours has disappeared there is the convergence option missing repair kit from www.tvrepairworld.com will solve the issue.
Jun 14, 2011 | RCA R56WH76 Projection Television
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
How to do convergence adjustment on 46 inch sony
Use your flash foucus or goto your menu - and choose convergece. Some sets may not have this feature. You can also put the set if service mode and make adjustments but I would not reccomend that unless you know what you are doing. None of the above will work if your convergence chips have failed. If that is the case you can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba rear projection 42h81 convergence problem
In that case the convergence Ic's are defective or "leaking" they must be replaced. these are the TDA's
Jul 09, 2009 | Toshiba 53H71 53 in. Rear Projection...
RCA picture not aligned and cant find in menu
iwould guess you might have the fl231 fuse problem check und tips and trick section in my profile and read the article
Jun 19, 2009 | RCA Televison & Video
Zenith R49W36 Rear Projection TV Convergence IC problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Jul 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
Auto convergence feature gone
Its the HV transformer, But if your symptom is auto convergence feature gone from the menu. Its not your flyback. Please respond to this same post with your model number and let me know if the auto convergence feature is missing, and I will assist you with the problem.
Jul 22, 2008 | Televison & Video
The convergence is way off on my projection rca tv - i lost the manual but i have set it before in a menu but caint remember how to get to it Was watching a movie, tv shut off and powered back on by...
It should be in the options menu. If not often RCA will drop the option when the convergence ICs go out and often the set will shut down. Heres alink that should be able to help you get a manual and parts if needed. If they dont have your manual leave an email and they should be able to get one quckly usually within an hour or two.
Apr 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba tv model # tp55h60
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 04, 2008 | Toshiba TP55H60 55" Rear Projection...
Can not convergence
Check for poor solder connections on both StK392-570 convergence Ics (Mitsubishi p/n # 267p150010) If there are none you may have to replace the amps - but that should restore normal convergence..
Bill
Dec 08, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
203 people viewed this question
Top Televison & Video Experts
