Question about Hotpoint Aquarius WMA42 Front Load Washer
Filter do you no were the filter on a hotpoint wma5 1000 spin is please
  • 332 Answers
THERE HAVE BEEN A FEW QUESTIONS ABOUT THIS, I LOOKED ON THERE WEB SITE AND IT DOESN'T SHOW A LINT CATCHER, BUT I DID LOOK INTO SIMILAR PRODUCTS AND SOME HAVE THEM UNDER THE DISPENSER FOR THE BLEECH AND FABRIC SOFTNER
Posted on May 29, 2009
My Hotpoint WML560 won't run a full cycle.
Is there a no spin button that has been pressed. Also some delicate cycles have no spin as part of the program.
Dec 14, 2014 | Hotpoint Washing Machines
Hotpoint wash and dry 5 5 wd 440 not draining/ spinning what do i do?
If not spinning, first check brushes on motor. If not pumping check filter (panel on front opens and front of filter unscrews and pulls out?) and pump ok
May 09, 2012 | Hotpoint Washing Machines
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hi i have a hotpoint washing machine,it spins ok with no load in it,but when i put a load in it the drum does not go into a spin
I would check the brushes in the motor if I were you, and also check the pump filter for possible blockage.
Thanks.
Nov 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Few12 will not spin after washing, any ideas
Had the same problem. Removed the kick plate at front and unscrewed filter. In the filter recess I found a cotton wool bud. Appeared to have stopped the blade like fan spinning which appears to push the water into the drain hose. Works perfectly now.
Aug 19, 2009 | Hotpoint First Edition FEW12 Front Load...
Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Spin cycle not draining
Hi-ya Brian
Probably blocked filter.
To locate and clean, remove rear panel altogether, locate large black hose at bottom of drum, remove from drum, and you will find the filter located inside the hose.
Check drain hose is not blocked also.
Thanks.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
159 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
