Question about Dryers
I have a Kenmore 400 series dryer. It is about two years old. I had an original issue of when the timer goes around to off it never reached off and the dryer kept running thus not signaling for my wife to remove the clothes. So, once she finally remembered to check the clothes,needless to say they were dry and HOT! Here is my problem now. When I press the start button;the dryer does not start. Can you help me with a few suggestions? Thank you.
  • 56 Answers
Sounds like your orginal problem was a blocked vent or kinked vent hose. Which in turn probably caused the thermal limt to burn out. It is located on the back and looks like a small piece of white plastic with two wires on it. part number 3392519 1-877-262-1479 Take the back cover off and look on the blower housing
Posted on May 31, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore 400 series washer does not seem to be releasing the fabric softener properly. It ends up all around the top if the barrel and spotted on my clothes as well. Anything I can do other than g
the dispencer can at times become plugged with old soap and farbic softener and should be cleaned every so often. if it cannot dispinse it will shoot out the dispenser all over when it goes into spin. the lines can even get plugged up and not allow fabric softerner to flow , u may want to remove fabric hoses and clean them
Nov 08, 2014 | Kenmore Washing Machines
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
My 400 series Kenmore dryer's timer is not working
if the timer will not advance through the cycles and the dryer is getting hot try the timed setting not the sensed setting and if the problem continues on the sensed side only it is not the timer it is the sensor , the sensor is what senses the temperature inside the dryer that is what advances the timer on the sensed side it could be that the timer could be good and the sensor be bad try that
Apr 03, 2010 | Kenmore 400 6943 Dryer
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Sears Kenmore Dryer 400 series won't start
Just some advice on the electrical components behind the machine. The thermal fuse (the long white fuse) should read continuity. set your meter to beep and it should beep. same goes with the thermal cut-off that's above the heating element, and same goes with the element. if it doesn't start, it's probably a thermal fuse. Good luck :) email me if you need help. appliance800@yahoo.com
Jul 15, 2009 | Dryers
Kenmore 80 series- wont shut off
it sounds like the timer is bad; expensive
also, the only way to get out something that fell into the blower box it to unplug the dryer and reach into the exhaust hole and try to reach it from there and if that fails then you have to take apart the machine.
Jun 27, 2008 | Kenmore 63942 Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
