Question about Jenn-Air JMC8100 Microwave Oven
Turns on when door opened
Microwave turns on when door opened. Model# jmc8100adq.
  • 2,005 Answers
This is dangerous; replace or adjust your door switches the interlock switches should only allow you to turn on the microwave when the door is closed
Posted on May 29, 2009
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Why does my Kenmore model 721.63352300 turn on when door is opened ?
The most likely cause is a defective door switch, there are usually a few to protect critical area's of the microwave oven, if you have a digital meter I can walk you through the testing stage.
Sep 02, 2012 | Kenmore 63252 Microwave Oven
I have a GE Microwave - labeled "Sensor Turntable" but unsure of model number. Microwave runs. However, when the door is opened, the microwave turns ON. Have reset our breaker. This does not...
Somehow you have a short somewhere or the door catch switch(s) contacts got damaged. If you are mechanically inclined, you can start by unpugging the unit and removing the case so you can inspect the door switch(s) assembly. Determine what is "normally open" and "normally closed" on the switch(s) and then Ohm them out with a multi-meter. Some of the switches are mounted on adjustment screws for propar contact on the door catches.
Nov 26, 2010 | GE Microwave Ovens
Microwave has power turn table works won't heat hotpoint model rvm1435bd 001
Check your door satey interlock switches.
If these switches fail (do you open the door while the machine is cooking?), the microwave doesnt know the door is shut and will not turn on the magnatron.
If you need more help, let me know.
a
Sep 27, 2009 | Hotpoint Microwave Ovens
Wont heat items in the micro or convection
MODEL NUMBER NEEDED
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
A PRELIMINARY OPINION
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
BEFORE YOU RATE THIS
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Dec 06, 2007 | Sharp R-510HW Microwave Oven
MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 05, 2007 | Panasonic NN-S254BF Microwave Oven
Jenn-Air JMC8100 Microwave Oven Logo
277 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
