Question about kawasaki Full Suspension Mountain Bike Men
BIKE KEEPS SHUTTING OFF
CHANGED THE OIL AND OIL FILTER ON BIKE CAUSE IT WAS SHUTTING OFF WHEN IT WOULD GET HOT, BUT IT'S STILL DOING THE SAME THING, IT SHUTS OFF WHEN IT COOLS IT STARTS RIGHT UP. COULD IT BE ONE OF THE SOLENOIDS?
    Champion:
  • 225 Answers
The coil is getting hot ,i would replace it.
Posted on Jun 07, 2009
Oil keeps getting into the breather changed pc valve hoses and filters
check sump oil level--excessive oil level will cause this
have a compression test done on the engine (both wet and dry) to determine engine condition---excessive blow by from worn rings , bore or cracked piston will cause this --- clean/ replace air filter as if there is a low pressure area after the filter , it helps suck oil vapor from the sump
Aug 06, 2016 | Cars & Trucks
Oil Pressure gauge is all of a sudden reading 80 psi! Was reading about 60 before. No change is the way truck runs. What is happening?
May be blockage in the system caused by either Dirt or heavy build up of carbon in system but more likely the filter is doing its job and his becoming blocked.
Change the oil when it is HOT and the filter and you should be OK
Aug 03, 2015 | 2005 GMC Sierra 2500HD 4WD
1998 pontiac grandam keeps shutting off....changed fuel filter and some gas line....any suggestions
if fitting new filter etc fixed for a while i would think ther eis some foriegn objects in the fuel tank , have it flushed clean and take it from there
Oct 21, 2014 | 1998 Pontiac Grand Am
Stalls when hot
check coils and pickups...both of these can break down when hot.
Aug 02, 2012 | Motorcycles
My dryer keeps shutting off every 10 to 15 minutes. I have changed the motor and it still does the same thing. The elements are good cause they have continuity thru them. I need help to get this problem...
It's difficult to say because there is missing info, but, the first thing I would look for in a dryer would be a clog on the exhaust to the outside of the house that might make the dryer overheat. There is probably a safety circuit breaker or overload that "trips" when the dryer overheats. It could also be that there is something stuck on the outside of the dryer drum that may be causing it to have higher friction than usual and possibly slowing down the motor.
Apr 23, 2011 | Dryers
Bike VFR 800 - 2006. Bought with 2000 Kms on the clock March 2010. Went well until 6000kms service done by Honda dealer. At 8000kms started leaking oil from filter. Checked tightness and found to be...
There are a number of simlpe things that you can do in this situation.1) only use Honda filters,I find some of the after market ones poor.2)Check the seat where the oil filter sits for burrs or nasties.3) Are you overfilling your oil,this will cause the oil pressure to go sky high and leak where it can.4) are you 100% positive that is coming from the filter ring,Many tines it comes from above the filter and the extra burns off misleading you into believing its the filter.I just went through the same thing with my bike and it tuned out to be a base gasket.You may have to strip away some plastic on the bike to get a good look.Good luck and good riding.
Nov 14, 2010 | 1999 Honda VFR 800
I was riding my bike the other day and it stopped taking gas but kept running eventually it stopped turning on altogther and we had to tow it home, today i changed the oil and oil filter. but when i let...
it's not normal for a bike to kills automatically because of the idle....you need to check your fuel filter might have a lot of gas particles , dirt, etc.or clean your carb, to have a smooth gasoline distribution.If this two thing were done and the prob still the same then, your ignition coil is no longer functioning normal.Change it. If you have that kind of symptoms for your bike then it can also be ignition coil, it automatically kills your bike when it become hot..
May 26, 2010 | 2006 Suzuki GS 500 E
Fuel leaking from air box after shutting down
Hi
Thats the float valve seals not shutting off, did you clean them & set the float heights?
The overflows from the carb bottoms must also be blocked for the fuel to fill up the carbs which then leaks into the air filter
Check also that the fuel tap turns off when bike is not running
Ride Safe
Bike-Doc
May 20, 2010 | 1985 kawasaki ZL 900 A1 Eliminator
Loss of power bike under performing
Check the spark plugs, they may need replacing.
Nov 20, 2009 | 1999 Yamaha FZX 250 Zeal
Car keeps shutting off
torque converter switch is bad.
Aug 03, 2008 | 1999 Oldsmobile Alero
kawasaki Full Suspension Mountain Bike Men Logo
90 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
