Question about Whirlpool Gold Black-on-Black 25.4 cu. ft. Side-By-Side Refrigerator w / Accu-Chill Temperature Control System GD5SHGXLB
No water going thru washer arms
2001 kenmore ultra wash dishwaser, it will fill and empty but will not wash. did diagnostics but no problem codes displayed.humming noise when in wash cycle The dishes in the top rack are not getting cleaned at all. The arm that sprays water to the top rack is not spraying any water...I have checked the holes are clean. Just happened a few days ago. For the last 2 years it was working fine. BTW we have Whirlpool gold.
  • saxena231 May 29, 2009
    Where is the pump screen located?
  • 1,869 Answers
Remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
Posted on May 29, 2009
Kenmore elite oasis washer will fill with water and skip the wash cycle. It will spin and empty then turn off. we have seen the code UL what can be done to fix this?
UL=Ultra Level of water?
usually its just foam in sensor tube,as prior using too much or wrong type of detergent(for hand wash,or else). Do few cycles with just and only water,or open machine and blow tubes to level "sensor".
Jan 24, 2015 | Kenmore Washing Machines
Kenomore ultra wash dishwasher will not clean dishes- water pump may be out? How do I perform self diagnostic test?
check and see if both wash arms are turning first.
does the lower arm turn but the top arm does not?
Another way to check to see if your upper wash arm is turning is to put a mug in the top rack upright. close the door and turn the dishwasher on if it fills the mug within 2 minutes you are getting proper curculation.
you press heated dry and high temp wash and toggle back and forth within 6-8 second. all the lights should light up and it will go into diagnostics.
Sep 03, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
Dishwaser does not fill
Hi. You can test the fill valve for voltage. If it is getting 120V and n water is coming in, change the valve.
Some models you can pull the float out.
When you lift it up and down, can you hear it clicking?
Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Check to see if the top rack wash arm water fitting is mating with the outlet on the back inside of the machine and the spinning was arm. This fitting can become displaced causing the water from the pump to just spray out into the washer and not clean the dishes on the top rack. it's usually just a matter of re-positioning the fitting and making sure it's connected to the top rack spinning wash manifold.
Apr 27, 2009 | Dishwashers
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Refrigerators Logo
126 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
