Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Won't print checks or anything from quicken but does for every other program. All I get is "spooling" and then nothing.
Please give me the name of a printer that WORKS with writing checks in Quicken using Windows Vista 64. My HP all in one does not - printer jams every time. i have office jet 6310 and it printed my checks fine until I got a new computer - it too is an HP pavilion dvo 1027 and now everything prints in all other programs but not quicken - nada - won't recognize it at all for anything.
If you do not have an updated driver available from your printer support website try this work around.
Step one: Go to start, go to printers, and right click on the printer you usually use. Click ports and make note of which port has a check mark. This is usually a USB virtual port.
Step two: back on the "printers" page, click add printer. When given the choice for which port, scroll down until you see the port that your printer was assigned to. Select that port.
Step three: When given the choice for printer to select, select HP Deskjet 990 C and install that printer driver.
Step four: if you want to you can change the name rename that one something to tell you it corresponds with your old printer. For example, in my case I called my check printer " QUICKEN 5740" which corresponded to my deskjet 5470.
Step five: go ahead and print a test page
Step six: Open Quicken and go to a printer setup. Select the printer that you just installed. Then open a report or try to print a check. Good luck. If you don't understand this try the HP site. Thats where I learned the work around. Works fine for me.
Posted on Aug 27, 2009
    Guru:
  • 224 Answers
It won't print you have to save the file on the desktop or in documents or anywhere away from the original and then try to print.all printers have issues with quicken deluxe they will not print from quicken deluxe unless it so happens b fluke
Posted on May 30, 2009
Quicken 2008 won't print anything in reports in black
You need to replace the Black cartridge, as it appears the colour one is fine. Look in the printer options on your PC for a display of ink levels, and you'll probably find the black down to zero. If you've used generic cartridges, not genuine HP, you may find the printer can't actually read the ink levels.
Feb 06, 2013 | HP Photosmart D7260 Printer
My MX870 is working fine. I can print and scan from the PC without any issues. However, I used to be able to scan receipts right from within my Quicken Home and Office software. What's really strange...
If it's viewing them, you should be able to save them to a file (should be doing this) - then uploading them into Quicken. It sounds like what you're saying is you used to be able to scan them directly using Quicken and now you cannot, and are having to use a different program.
Open Quicken and go into the file menu and look for "setup" or "options", "print options" "scan", words like that. There are way for setting, resetting these options, and you will need to locate this. I apolgize, as I am not directly familiar with Quicken itself, but with all other programs that have documenting, printing, and scanning options, they are all basically the same.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jul 01, 2011 | Canon PIXMA MX870 Wireless Office...
Quicken reports won't print
Go to printer under control panel and right click on the printer - select printer properties...advanced tab...check print directly to printer. Checks should print now. Downside...everything prints directly to the printer (no spooling) which can be slow at times. Also I have found printing pdf's using this option won't print so you'll have to change it back. I'm using Windows 7
May 06, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have Quicken 2009 and Windows Vista, HP Printer
I've tried off and on for a year to try to get assistance from Quicken and HP because my Quicken reports would not print. Everything else printed just fine. It was so frustrating because nothing worked. I needed to get reports to my accountant and thought I was just going to have to hand write the reports. In the end, I took a photo of the screen (with the report showing), downloaded the photo to the computer, tweeked it a bit with my photo software, then prrinted it. How goofy is this to get a report from a program that is supposed to make my life easier???!!!
Aug 19, 2009 | Computers & Internet
Have Quicken 2008 and HP J6400 printer. Can print reports but can not print checks
Check that the problem is not caused by mismatched paper size, in that case you may need to correct printer settings and adjust also settings on Quicken.
Quicken 2008 is also known for having several bugs that affect printing, if you are considering an update to 2009, that should fix the problem.
You can also check if a patch to fix the problem is available contacting quicken online, check the links below:
Quicken® Personal Finance Software: Chat
Get Help with Quicken | Quicken Help and Support Options
Regards.
Jul 27, 2009 | Computers & Internet
Printing check from Quicken 2009 Deluxe
All Printers have this issue printing from quicken you would need to download the older version of quicken from oldversion.com
Then uninstall the new version and install the old version.
all lexmark/canon/epson/brother/hp.....printers have this problem with the new quicken.
Or try calling in to us at 1800-474-6836 and provide us with a remote session with your computer we may be able to fix this issue with a basic driver.Let me know if you have connected the printer thru usb or ethernet and I will give you a resolution that works 70% of the time with the new quicken
Jun 16, 2009 | HP OfficeJet 6310 All-in-One Printer...
Quicken 2009 won't load any more. using windows vista.
Ok, this basically means the ini file is corrupted normally. What you'll have to do is either reinstall quicken 2009 or try a repair on it. You can also manually go to c:\Program Files\Quicken\qw.exe and see if the shortcut is bad that you have been using. If you don't have the disk, go to start, settings control panel, add remove programs or programs and features. Locate the program. Right click on it, click change. Then check the feature that gives you the option to repair the software. BACKUP quicken files if they aren't on a disk.
Jun 11, 2009 | Intuit Quicken 2008 Deluxe Full Version...
Won't Print Quicken Checks- Canon MP620
Here is all I could find, as it is a compatiblity issue and not a repair issue. Hope this helps. You can also get on an online instant chat at www.hp.com and they may also have some answers for you.
HP has apparently released new printer drivers for some of their
> printers that will fix at least one print problem experienced by
> Quicken users.
> If you have an HP printer and are having problems printing from
> Quicken and you use 64 bit Vista, check this HP faq to see if there
> may be help for you.
> http://tinyurl.com/89ly3u
P.S. It appears that the fix will apply to more printers than are named in
the faq; The way I understand it, if there is a version 12 driver available
for your printer model, you probably should get it.
Apparently the list of printers to which the fix applies will be updated at
some point.
Don't forget to rate this 4 stars before you log out. If I can be of any help let me know.
Feb 01, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Quicken 2008 printing vista 64
There is an issue with Quicken 2007 and 2008 printing to many HP printers. Workarounds: 1) print to the Quicken PDF virtual printer, then print the resulting PDF file. or 2) Install a Deskjet 990 driver (using the add printer command) using the same port as the Officejet 7410 is installed.
Regards,
Bob HEadrick, MS MVP Printing/Imaging
Nov 02, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printing PDF files
I had this problem after I had fixed a problem printing from Quicken. I was able to print from Quicken by changing the print option in Windows -- mine was set to "Spool documents" and I changed it to "Print directly from printer" -- the advice I was given was to change it from whatever it was set at to the other option. For printing a PDF file, I changed it back to "Spool documents" and it allowed me to print the PDF file. Try this and see if it works for you -- click the Windows Start button and select Settings, then Printers and Faxes. Right click on the selected printer and select Properties. In the properties window look for a setting to print directly to printer or spool documents -- mine was under the Advanced option. Try the option not currently selected -- in my case, I changed it back to Spool documents with Begin printing immediately -- and then try to print a PDF file. It looks like I will have to toggle back and forth when I am printing from Quicken and when I am printing a PDF file. Hope this works for you.
Mar 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
757 people viewed this question
Seeker5211
Seeker5211
