Question about KitchenAid KUDR01TJ Dishwasher
Loud grinding noise when washer is draining
The cycles start up ok buy the is a loud grinding noise when it attempts to drain. Is there a way to clean the drain/trap? (never been done) the unit is apporx 4 years old.
    Novelist:
  • 148 Answers
Something in the impeller housing. not usually serviceable. not sure if that unit has two pumps. you could look underneath the tub and try to determine that, and where the noise is coming from.
i am confident the issue relates to a pump unit.
good luck
mark
Posted on Dec 28, 2007
My washer just came to the end of the wash cycle and started making a loud grinding noise when it is time to drain. It won't drain.
from your description , there is something interfering with the impeller in the water pump
could be button, coin , hair clip, bra wire that has damaged the impeller blades
Rather than mess around trying to repair I would just get a new unit as the same time and difficulty is for both operations
Dec 10, 2015 | Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Admiral aav-1 makes loud grinding will not spin or drain
Hi, the drain pump impeller is damaged. you will need to replace the entire pump(drain) in this case.
You will hear this noise when the impeller become separated from the actual drive stud or, shaft.
Jul 13, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid KUDR01TJ Dishwasher Logo
442 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
