Question about ASUS Eee PC 900 Notebook
I broke my asus eee pc 900 and couldnt start windows. so i tried installing from the xp disk..ive used 4gb thunb drives..external dvd drives. and i always have an error when trying to install on the hard disk. is there a way i can reformat the hard disk from bios?
  • Marcelo Escobal
    Marcelo Escobal May 11, 2010
    ¿Can you post the text of the error? I need more details before atempting any solution.
  • 479 Answers
most of the times if laptop or Desktop cpu falls then HDD is the very first part to be damaged.
You can try any third party software as partition magic or DM for formating the drive.
Posted on May 29, 2009
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
Im getting a disk read error and eee pc 900 notebook wont even boot up. i mean not show windows at all. i have windows xp. need help
It's a hardware failure - the hard disk has died. You will have to replace it then reinstall using an external cd unit and an XP install disk - ideally the recovery disk should be used.
Jan 15, 2011 | ASUS Eee PC 900 Notebook
Can I install windows on the Eee PC
Yes it is possiable to install Windows OS on the machine.
you would need an unpartitioned space on the Hard disk depending on the OS.
Win xp : 900 MB
Win Vista: 1.5 GB
Win 7 : 2 GB
you would also need a windows bootable disk.
once you have the above, change the first boot device in the bios DVD, insert the bootable CD in the CD Drive, restart the computer and follow the screen instructions
Jul 11, 2010 | ASUS Eee PC 1000H Laptop
Eee pc asus 904hd xp, corrupt registry
you can install windows XP from a Pen Drive/Flash Drive provided that your motherboard supports booting from USB drives.
Further detailed instruction can be found here.
http://www.troublefixers.com/solved-install-windows-7-from-usb-pen-drive-with-iso-image-without-cd-dvd-drive/
Oct 08, 2009 | ASUS Eee 4G Notebook
I have an asus eeepc 900. i have an error message
hi charmed4031this netbook comes with an internal harddisk on which windows is installed but lacks any optical drives so far.
You will have to get an external CD/DVD-drive plus a Windows-CD for it from which you safely can reinstall windows or replace the missing file. Please find out which windows version you are using(Win200, Win XP Home for e.g.,), lend or buy this external drive, connect devices and let the computer work it's magic, if still facing diffifculties, you know where to find us ;-)
Sep 18, 2009 | ASUS Eee PC 900 16G Notebook
Asus eee pc 900 /windows/system32/config/system
2 problems, your using a netbook that doesnt have an optical drive (cd/dvd) and you need a windows cd.
I dont think there is anything you can do until you call your retailer and request a copy of windows cd.
After that you can do a windows repair. Use the link below to see you options for accessing the cd once you have it.
http://www.itworld.com/windows/68069/three-ways-install-windows-7-netbook
Aug 29, 2009 | ASUS Eee PC 900 16G Notebook
ASUS eeePC 900 Keeps rebooting at XP load screen.
You're computer is booting that's not your problem. Its just not booting into Windows which is a different subject, so a boot disk will not do you any good. You have some corrupted files at the Windows end not the start up end. The only way to correct the Windows corrupt files is to use a Windows disc. So you'll have to buy/borrow a portable DVD/CD player and a copy of windows. Once the Windows disc loads then its just a matter of clicking on "repair" when the disc asks..that one of the drawbacks of netbooks..If you have any questions let me know..
Apr 20, 2009 | ASUS Eee PC 900 PC Notebook
How to reformat ASUS Eee PC 900 notebook?
I have the linux version, not sure if you have the windows version or if it really matters. If you are looking to "reformat", you can go with the other suggestions with the USB stick. However, if you are reformatting to get back to the default settings, power on the computer and immediately hold F9. This will bring you to a screen that gives you the option to "restore factory defaults". You will lose all your previous settings, but if you were reformatting anyway, that's probably not a big concern.
Jan 13, 2009 | ASUS Eee PC 900 Notebook
Install Window XP into Eee PC without external DVD drive?
Each computer needs its own operating system in which you do you have linux as a pre-install. If you want XP, you will need an external dvd/cd rom drive. It is worth it if you think about it...running xp, you're bound to run into other software you will likely need in the future, so getting an external cd/dvd drive would not be a waste of your money.
Nov 16, 2008 | Computers & Internet
Asus operating syatem
Ok your gonna need a couple of things to put XP on the Linux Eee PC.
A usb 2.0 CD or DVD
The Offical windows XP service pack 2 disc from Microsoft
A usb flash disk larger than 1 gig or an external harddrive
ASUS PC Eee support CD from original package.
If you have those things the ASUS Eee XP installation instruction manual can be downloaded here
May 01, 2008 | Computers & Internet
ASUS Eee PC 900 Notebook Logo
254 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
