Question about HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
Color Laserjet 2550 Loud Noise when starting up and printing
It started to make a sort of groaning noise once in awhile but it still printed. Now it makes a very loud long noise as it starts up and it goes on for 30-40 seconds. It still prints but it sounds very bad as if something is caught or maybe needs oil. I don't want it to break down and not work. Any ideas? HP was no help said it was out of warranty. Thank you. It is worse when printing from the manual feed tray.
  • 489 Answers
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
Posted on May 29, 2009
I replaced my imaging drum and it no longer makes the loud groaning noise.
Posted on Jun 06, 2009
  • kaydiane57
    kaydiane57 Dec 23, 2012
    Thanks for your comment, How do you replace the drum? Thanks again Di
    Problem Solver:
  • 7 Answers
I've just had a similar problem with a grinding noise. But the printing was bad. It turned out that the roller gears on the black toner cartridge would not move. In spite of taking the end off the cartridge and blowing it out, I could not find out why, so I replaced the cartridge.
Posted on Dec 18, 2017
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Replace transfer roller
Groaning noise on this model is usually down to third party consumables, Has this noise started after recently( within 5000 prints) replacing one of the colour toners cartridges, If so - you should replace the same cartridge with a HP OEM product and see if this cures the fault 99%of the time third party consumables do not replace key components when Re-Manufacturing Toner/Drum units to save on cost - however this causes Major issues with the expected Life of the Printer as A whole. Added stress on the drive systems due to poor toner units will invalidate any warranty/Repar Cover you may have, Despite what the adverts say CHEAPER toner Units Do Not Give You Cheaper Prints. They Just amage the rest of the Machine>>>>...
Sep 13, 2013 | HP CP3525DN Color LaserJet Printer
HP laserjet 1200 series printer makes a groaning whining noise when it starts up to print; noise continues until it stops.
Sorry, it's old, cranky, and worn out. Live with it, or buy a new one, it's not cost effective to fix it.
Oct 14, 2009 | HP LaserJet 1200 Printer
How to start HP color Laserjet 2550 printer HP Laser Jet 2550 Printer
first your printer connected to your PC and install the printer software for printing. After Installation you press the power button of your Printer, so your printer is on go for Printing Documents/Pictures.
Thanks
Aug 16, 2009 | Office Equipment & Supplies
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Hp4700 Color laserjet makes groaning noise
Could be dry fuser bearings or a noisy transfer belt.
Jan 06, 2009 | HP LaserJet 4700 Printer
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
Loud noise
If your also encounter prints that have a roller/crease at the right and slight crinkling at the left then your fuser should be replaced.
Nov 19, 2007 | HP Color LaserJet 2600n Printer
Squeaking noise when printing
This is a duplicate posting; here is the link to the active posting: http://www.fixya.com/support/t132706-squeaking_noise_when_printing
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
1,572 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
