Question about Aiwa XP-SP90 Personal CD Player
It won't play anymore. All I get is a HOLD message.
My Aiwa cross trainer Cd player only says HOLD when I push play. Nothing I have pushed changed that and new batteries didn't help either.
  • meteshadow May 11, 2010
    the hold switch breaks ?
informatica
  • 1114 Answers
SOURCE: Aiwa CDC-X304
You can download the manual from the link below: http://www.us.aiwa.com/default.asp?page=ownerManual&action=browse&model=418
Posted on Aug 06, 2007
SOURCE: HOME STEREO SYSTEM CD PLAYER
aiwa cx-na508
Posted on Jul 28, 2008
panthers85
  • 54 Answers
SOURCE: won't play
Look on your player for a hold button or switch. When you find it turn it off.
Posted on Aug 10, 2008
SOURCE: Display issues with Aiwa CDC X207
I had the same problem. There are two small light bulbs that illuminate the digital display, and they are burned out.
You can easily replace them. The Aiwa part number for them is 8Z-KT1-641-010. The bulb is made by Sony, and the Sony part number is U0087654U.
I purchased them from Union Electronic Distributors:
https://www.ued.net/ued/addItems.do?itemCode=SNYU0087654U
Note that the product is not an item they keep in stock, so it may take 1-2 weeks or more before you receive them. Be patient.
Here are the steps to replace the bulbs. You will need a small (#1) Phillips screwdriver and a soldering iron (low heat). A very small flat blade screwdriver (1/8") will also be helpful.
1) Remove the faceplate from the radio and bring it to a well-lit work table.
2) Remove the four Phillips screws on the back on the faceplate.
3) Carefully separate the back half of the faceplate cover from the front half. There are three locking tabs along the top, and three locking tabs along the bottom. I used the small flat blade screwdriver to separate the two halves.
4) Once the back half of the faceplate has been removed, re-install two of the Phillips screws to hold the circuit board in place (one screw on each end). You don't need to screw them down tightly; just screw them in until you begin to feel them stop. These screws will keep the circuit board from separating from the front faceplate and causing the buttons to fall out!
5) Locate the two bulbs. They are labeled PL 901 and PL 902 (may also be labeled PL 1 and PL 2). Carefully unsolder the bulbs and remove them from the circuit board. You may want to do one at a time.
6) Each bulb has a colored cover to change the color of the light (I jokingly refer to them as 'bulb condoms'). Remove the covers and carefully slide them in place on the new bulbs. You may want to slightly dampen the bulbs to aid in sliding the covers on. Be sure to slide them all the way down.
7) Solder the new bulbs in place. They are not polarity sensitive.
8) Trim off the excess wires.
9) If you installed the two screws in Step 4, remove them.
10) Carefully re-attach the rear faceplate cover to the front faceplate cover, making sure that all six locking tabs snap in place.
11) Put the four Phillips screws in the rear faceplate and carefully tighten them.
That's it! Now, put the faceplate back on the radio, turn it on, and enjoy your lighted display!
Hope this helps.
Ron
Posted on Feb 15, 2009
  • 15 Answers
SOURCE: my cd player keeps saying error 3 what does that
its because of data memory corrupt.. u might need to flast your memory of ur cd player
Posted on May 29, 2010
Getting my aiwa to play cds or cassettes. Bought second hand no instructions .lights up won't play can I get instructions on how to get sound?
You don't state the model, so we are running blind here. It should be fairly obvious. For the CD press the CD button. Then press the door button and put the CD on the tray. Then press play or the door button again. If the CD player works it should play the music. Same with the cassette. Drop the cassette into the holder, push it back in place then press play.
Oct 07, 2017 | Aiwa Audio Players & Recorders
Aiwa stereo is working but no sound
try crossing over your speaker wires , criss cross them from like A top and B bottom. then there ussally are 2 button that control the speaker out puts. Find the buttons and try pushing them in and out until u get sound. hope this helps
Jan 25, 2013 | Aiwa Audio Players & Recorders
I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
I think that's Demo mode.
I got stuck there too.
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Jul 26, 2011 | Aiwa CDC-X204 CD Player
My cd player keeps saying error 3 what does that
May 28, 2010 | Aiwa CDC-MP3 CD Player
-Hold button keeps displaying
The unit has a hold button that keeps you from accidentally activating the device when it's in a purse or backpack, which preserves battery power and also prevents changing tracks if buttons are accidentally pushed while in play mode. Look on the player for the hold button and turn it to the off position. I hope this helps and good luck!
Feb 17, 2010 | Philips eXp2461 Personal CD Player
Won't play
Aug 10, 2008 | Aiwa XP-V5260C Personal CD Player
Cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Jan 28, 2008 | Tascam CD-A500 CD Player
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Jan 16, 2008 | Aiwa CDC-X304 CD Player
Aiwa XP-SP90 Personal CD Player Logo
81 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
