Question about Whirlpool Duet GHW9150P Front Load Washer
Duet washer code f 33? What does it mean?
What does it mean?
  • 1,889 Answers
The fault code indicates that your main data cable from the controller to the motor has miss-comunicated: unplug the washer wait about 30 minutes then plug it back in and, let me know if the code clears
Posted on May 29, 2009
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Fault code f-33 on a whirlpool duet.
The F33 code is a pump failure code. The control unit is not measuring the proper amp draw on the pump during pump out. Remove lower panel and unplug then replug in the pump 2 or 3 times to remove any corrosion. While your down there, take the front of the pump off to check for any blockages.BE SURE TO UNPLUG YOUR WASHER WHILE SERVICING!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an f/33 error message on my whirlpool duet washer how do i fix it
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 26, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Code F 33 on whirlpool duet waher. Sevice guy
i think that has to do with not filling .. does water enter machine. is it filling slow?
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't complete the cycle falshing F 33 whirlpool duet
f-33 means that the washer is leaking.did you put too much soap in the washer? you may need to check the hoses .otherwise it may be leaking underneath.good luck!
Jan 18, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My duet keeps flashing f-33. what does this mean?
if after 30 seconds the comtrol does not detect water entering machine,the water valves be turned off and the error code will be displayed.or if the control has turned the water valves on and after 8minutes the flow sensor has not dettected 10.5 gallons of water passing through it,but has not detected the pressure switch trip,the valves will be turned off and the error code will flash.check for crack or holes in the hose from the pressure switch to the outer tub,also check the hose for wereing thin do to rubbing some were on unit.also if you put to much detergent in washer it can make the unit think that ther is 10.5 gallons and the code will be displayed.if this is the case than you nead to run the clean cycle 1or2 times.
Jan 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-33
Hello there
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
175 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
