Question about Canon PowerShot Pro1 Digital Camera
Fuses on the Powershot pro1
Does anyone know where the surface mounted fuses are on the Pro 1?  I understand that there are 3.
The service centre will only replace the PCB so this will cost more than the Camera is worth.
Interesting that a blown fuse writes-off the camera, when fuses are there for safety and to protect you valuable assest!
  • canonjunk Apr 18, 2008
    I have the same problem with my camera, It was fixed 8 months ago... The repair shop said the replaced the board, I think it was the fuses.... The cost was great.... But I have a nice paper weight by canon.... pleas help...... realtors911@aol.com
    Novelist:
  • 198 Answers
Hello
You may find the fuses by using a ohm meter or anything that has an ohm meter (a digital one is needed). First turn the ohmeter on the smallest scale possible (100ohm, 20 ohm or whatever your device has). Then short circuit the test pins and check to see what value does the device show. You may see something like 0.04 or 0.08 or similar. That's normal. Now on the pcb look for small sqare or rectangle components near the battery compartment and near the dc in plug (if you have any). A good fuse will show you, when measured, the same value with what you measured before when you short-circuited the test pins). If you are sure that there are 3 of those look carefully on the pcb, they should be similar and at least one of them shouldn't be broken. if you find it and it shows the right value on the ohmeter look for the other 2 and also measure them, if they display different values or nothing at all, they are broken. In most cases a fuse has a small notation near it on the pcb something like F-108 or F-607 or something begining with F. This may help you identify them.
I'm sorry for not being able to provide a more accurate description, however only the camera's service diagram could give a direct answer. This can't be found on the internet as only authorised service centers have it and they aren't in the mood to share it.
Posted on Oct 22, 2007
How to remove the lens of the Canon PowerShot Pro1 Digital Camera? If it cannot remove, how can I disassembly the front of the camera with the lens? And is there are some pictures and graphics to show
Does not matter how you remove the lens, because once you got it of, you never can get it back on, so your camera can use it. Assembling a camera lens is a very delicate job, and only the slightest miss alignment makes a lens worthless. This kind of repairs should be done in a Canon certified repair centre. But first ask what it will cost, but if it costs more then a new camera, you better start saving for a new camera. The cameras becoming better and better every year, and in the same time they are cheaper and cheaper.
Sorry, but if you really want to try it yourself, because you don't mind what the result will be, please look on the site fixit dot com. The take apart all kinds of electronic equipment. (they don't show how to put it together)
Oct 29, 2014 | Canon PowerShot Pro1 Digital Camera
Lens retraction noise in canon powershot pro 1
The lens needs to be dismantled, cleaned and lubricated by a camera specialist, the alternative is a lens that will eventually seize, shutting down the camera.
Apr 08, 2012 | Canon PowerShot Pro1 Digital Camera
SONY KP-65WS510 TV LOOKS LIKE TYPICAL CONVERSION CHIP PROBLEM. SCREEN HAS BOWTIE EFFECT AND CONVERGENCE IS ALL WACKED OUT. CHECKED ALL "D" BOARD FUSES AND REPLACED CONVERGENCE CHIPS. PROBLEM REMAINS THE...
there are fuses on each driver (6 in all) under the heatsinks usually.. make sure these are good. there are also 2 5amp fuses on the g board that supply power to the chips + and - 24volts.. check both of these.. i've seen some check good in circuit and still are bad, check voltage to see for sure. In a rare case, i knocked off a small surface mount resistor when unsoldering the chip, and then the convergence was muted.. make sure no small surface mount parts were moved on the bottom of the board when you soldered. good luck, let me know wif you need futher assistance.
Jun 19, 2010 | Televison & Video
Hi.. Can you tell me as to what is the maximum CF memory card that can be used with Canon Powershot Pro1
When this model came out a 1GB card was a large capacity card, so Canon's specifications stop there. I talked with a friend who has used a 4GB card in a Pro 1, and it's possible that it may work with capacities even larger than that. But I think you will be able to use a 4GB without problems.
May 07, 2010 | Canon PowerShot Pro1 Digital Camera
Lost lens cap
http://www.bitssite.com/canon-powershot-pro-1/2827/rear-lens-cap/accessory.html
That should be the cap your looking for if not let me know. Please take a moment to rate my solution fixya if it helps.
Thank you,
Lee
Jan 04, 2009 | Canon PowerShot Pro1 Digital Camera
I also have the same problem and I took it to the canon service center. They told me that I have to replace the whole lens kit the problem was with the shutter not closing properly thus overexposing the pictures
Feb 26, 2008 | Canon PowerShot Pro1 Digital Camera
Projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Nov 12, 2007 | Mitsubishi XL8U Multimedia Projector
Nec mt/1040
Doug.
Nov 06, 2007 | NEC MultiSync MT1050 Multimedia Projector
Canon PowerShot Pro1 Digital Camera Logo
136 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
P.J. Ryan
P.J. Ryan
Level 1 Expert
Are you a Canon Camera Expert? Answer questions, earn points and help others
